Badge removal? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by yamaman, this thread has received 5 replies and been viewed 3291 times.
post #1 of 6 (permalink) Old 04-08-2010, 03:35 PM Thread Starter
Badge removal?
Hey anyone know what hides behind the factory badge son a 2006 F-350? I want to remove the f-350 badges and the powerstroke ones but is there alignment holes behind them? Thanks guys.
yamaman is offline
post #2 of 6 (permalink) Old 04-08-2010, 04:19 PM
Slow 6.0
theres alignment holes behind all the F350 emblems, even the tailgate. there arent any behind the powerstroke badges tho
2006 F350 XLT 4x4
SICKS-O is offline
post #3 of 6 (permalink) Old 04-08-2010, 08:39 PM Thread Starter
Thanks man looks like the powerstroke ones will be the first to go then, until I get alittle time to do some body work. Thanks man
yamaman is offline
post #4 of 6 (permalink) Old 04-25-2010, 02:03 PM
TexasTruck's Avatar
Images: 1
Yes, there are two if I'm not mistaken. I used high test fishing line between my hands and used it like a saw to slice through the double stick tape. When I reached an alignment pin I "fished" the fishing line around it. Worked great. It takes a few lengths of fishing line though. The friction eventually breaks the line. Hope this helps.
2008 Silver CC FX4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness
TexasTruck is offline
post #5 of 6 (permalink) Old 04-25-2010, 03:11 PM
bushpilot's Avatar
the "powerstroke" on the door are simple stick on's
the f350/250 on the fender have pins thru the fender <youll have to puddy/weld and
paint after you remove those>
Don R.
Truck Audio,
bushpilot is offline
post #6 of 6 (permalink) Old 04-25-2010, 04:49 PM Thread Starter
thanks guys
yamaman is offline
Badge Removal Flopster843 Dodge - Modification instructions, Product installs and Tech Articles 1 05-21-2009 07:23 PM
Power of the Badge RussK The Parking Lot 12 04-10-2009 02:51 AM
Badge Removal and installation ckbed The Detailing, Paint & Bodyshop 4 05-18-2007 04:54 AM
New Badge 4cstr 2008-2010 6.4L Power Stroke 11 09-17-2006 08:33 PM
badge question... kkibbey 2003-2007 6.0L Power Stroke 3 06-16-2006 12:53 PM
