Rolling Rumble Puzzler - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Old Timer 2, this thread has received 5 replies and been viewed 877 times.
post #1 of 6 (permalink) Old 04-08-2010, 11:58 PM Thread Starter
I'm driving my 2005 King Ranch, 6.0, 2wd with no problems until now...
it's got 53,500 miles on it and just like a bad habit there is a rumble, sounds like it's coming from the front, like a wheel bearing goin bad... turn off the engine at 35-40 and it's easier to hear... thought it was tires but on a gravel/clamshell drive way at 20mph I can still hear it...
pulled both axels in the back, stuck my magnet in there, not a bit of trouble on the magnet... did the same for the front wheel bearings, took out the outer bearing and stuck the magnet in there, nothing...
This has me puzzled and my wife cranky!
It's not the front brakes draging either and the noise does not change when the brakes are applied...
U joints are tight, caarrier bearing seems just fine...
Looking for some guidance with this... any simelar experiences for anyone?
Old Timer 2 is offline
post #2 of 6 (permalink) Old 04-09-2010, 02:59 AM
4play's Avatar
Sounds like you are describing a bearing type noise. Sometimes if its a front wheel bearing you can change the noise by turning or swerving the truck. If you turn left and noise gets lighter or goes away its usually the left bearing, same goes for the right side. Also lift the tires off the ground and grab the top and bottom of tire and see if you can wiggle it in/out. if you have movement there is "play" in something. sometimes it helps to have someone move the wheel/tire while you are under truck looking for whats moving.
4play is offline
post #3 of 6 (permalink) Old 04-12-2010, 12:41 AM
Mod Friendly Title
Zaairman's Avatar
Kick it into 4x4 when it's making the sound and see if it goes away. Sounds like a needle bearing on your wheel bearing assembly.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #4 of 6 (permalink) Old 04-12-2010, 03:48 PM
lilpooh's Avatar
It's a 2wd!!
2004 F350 CC DRW King Ranch
lilpooh is offline
post #5 of 6 (permalink) Old 04-12-2010, 04:33 PM
Mod Friendly Title
Zaairman's Avatar
Originally Posted by lilpooh View Post
It's a 2wd!!
So you're saying he might have problems getting it into 4x4?? :
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #6 of 6 (permalink) Old 04-17-2010, 01:09 AM
bigastrk's Avatar
If the brakes are acting up I would say it the bearings. Just like everyone else has pointed out but while you are checking that you may want to check the ball joints cause they have been know to go out early also. Just something to think about if you have it apart at a shop you wil save some labor in the long run.
03 6.0L Excursion < Sold
bigastrk is offline
need a rolling frame GUTTS 2008-2010 6.4L Power Stroke 11 02-04-2010 07:03 PM
rolling idle yadaddy99 2003-2007 6.0L Power Stroke 6 08-01-2009 09:00 PM
Click while rolling brendonv 1994-2003 7.3L Power Stroke 9 05-09-2009 05:31 AM
rumble kkdiesel7 1994-2003 7.3L Power Stroke 7 12-07-2007 04:13 AM
79` f350 4x4 rolling chassis BogginF350 Whats Been Sold 4 12-07-2006 07:14 PM
