I need photographs of the front frame of your 95 though 98 F350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 2 replies and been viewed 856 times.
post #1 of 3 (permalink) Old 04-12-2010, 05:59 PM Thread Starter
I am converting my two wheel drive F350 to a four wheel drive and I am using mostly factory parts. The problem is I have had my donor truck torn apart so long I have forgotten how some of the parts go on. Right now I am welding in holes and I almost welded in some I need. So to save a lot of unnecessary work I was hoping any one on here with a Factory four wheel drive 95 though 98 F350 can post photographs of your frame section from the first body mount under the cab to the body mount under the radiator support. I also need photographs of the track bar and how it is installed along with where the leaf springs and front end bolt together. Thanks in advance for your help; I really want this portion of the build done as soon as possible.
post #2 of 3 (permalink) Old 04-20-2010, 11:47 PM
Haulin' Hay
NCfarmboy's Avatar
Good luck with the conversion... I remember seeing pictures of this a while back. Can you post some update pictures?
NCfarmboy is offline
post #3 of 3 (permalink) Old 04-20-2010, 11:54 PM Thread Starter
Well damn. I was going to post some I took a couple of days ago and they are no longer on my disk. Strange...
92 to 97 f350 4x4 axles frame beefy spring BLKTRUCK1 Ford Parts 2 03-05-2010 05:10 PM
Arial photographs over Iraq Lonesome7.3 The Parking Lot 14 03-30-2009 12:12 PM
Ford F350 73 79 4x4 truck frame Lonesome7.3 Whats Been Sold 6 07-24-2006 06:45 PM
photographs of my new 06 Sierra/LBZ jdk Duramax 2006-2007(LBZ & LLY) 33 06-13-2006 04:06 AM
If you have a 95 through 98 powerstroke, please post photographs or your wiring H Lonesome7.3 1994-2003 7.3L Power Stroke 4 05-28-2006 01:04 AM
