rear hatch struts on excursions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skippy, this thread has received 5 replies and been viewed 7212 times.
post #1 of 6 (permalink) Old 04-17-2010, 02:48 AM Thread Starter
HalfAst Racing
skippy's Avatar
Images: 1
Thumbs up rear hatch struts on excursions
heres a little trick i just learned.ford put two different length struts on the rear hatch of excursions dependent on whether its 2wd or 4wd.mines a 4wd and they put shorter struts on i guess to make it easier to reach on the slightly taller 4wd?i dunno i just know its annoying that it doesnt open far enough,i needed new ones anyways so i ordered a set of 2wd lift struts that are an inch longer extended.im guessing that the location on the hatch will equate this to a couple inches higher opening hopefully.25 bucks for the pair on ebay,38 each from ford.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
post #2 of 6 (permalink) Old 04-17-2010, 05:48 AM
Stuck in Commiefornia...
IdahoF350's Avatar
Yeah, I found this out when I bought mine. I whacked my head on the hatch (I'm 6'2" barefoot and 6'4" with my boots on) and since it needed the struts replaced I called my guy at Ford to order a set. He tells me about the difference, and that the 2wd set raise the hatch more to offset the 2wd being lower and make it easier to put stuff in the back or some bs like that. So I bought the 2wd ones, put them on and my head is since without dings. Here's the best part, my wife is 5'0" tall and she has no problem reaching the hatch even with the longer struts!
2000 Excursion XLT 4x4
IdahoF350 is offline
post #3 of 6 (permalink) Old 04-17-2010, 11:28 AM
4cstr's Avatar
Images: 35
so I take it the 2wd struts fit the 4wd Ex's just fine?
This is awesome news. I need to replace the struts on mine and also wouldn't mind having the gate lift a bit farther.
~Dave~
4cstr is offline
post #4 of 6 (permalink) Old 04-18-2010, 01:45 AM
IdahoF350's Avatar
That is correct, they interchange. There are no differences in the hatch or the body, just the extended length of the gas struts. You will probably noice the first couple of times you lift it that it goes up slower the last couple inches because it hasn't gone that high before and the hinges get dirty, but after a few openings, you'll never know it was ever different.
The Following User Says Thank You to IdahoF350 For this addition to TDG:
4cstr (04-18-2010)
post #5 of 6 (permalink) Old 04-21-2010, 07:48 PM
Obviously Intuitive !
swapped out both my 03's and 05's for the longer ones.... just remember to have a STRONG board to support it when u swap them...
that liftgate is HEAVY
4x4 had the shorter ones because they sit higher and 'someone' thought it would protect the liftgate and fit in more garages if it didn't go higher
02/12 f250 CC SB Lariat Ultimate 4x4
dpf filter back mbrp and airlift airbags
05/05 4x4 EB Excursion -gone but not forgotten SCT enabled 1/8th 8.9 seconds....
JohnBoyToo is offline
post #6 of 6 (permalink) Old 04-21-2010, 10:44 PM
bigastrk's Avatar
Hahahaha I put the 2WD ones on my ex and next thing you know I have to jump to reach the handle....
03 6.0L Excursion < Sold
bigastrk is offline
Oasis report on two Excursions please myf350 Ford Oasis requests 2 02-07-2010 04:23 AM
Brands Hatch test Tech Guy Testing 5 10-23-2009 02:41 AM
Show me some Excursions Squatch General Ford Truck and Excursion 12 07-11-2009 02:37 PM
1984 dodge daytona hatch DBogo Whats Been Sold 0 07-23-2006 02:41 AM
Daytona hatch DBogo Whats Been Sold 0 05-29-2006 03:01 AM
