Ball joint info please help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ChrisSheerman, this thread has received 10 replies and been viewed 14377 times.
post #1 of 11 (permalink) Old 04-20-2010, 05:50 PM Thread Starter
ChrisSheerman's Avatar
I'm getting ready to do the ball joints in my 05 f250 please could someone tell me what the ball joints and tie rod and any other nut the needs to be torqued for this job what the recomended torque spec are.
2005 Ford F250 6.0 auto 3.73 srw XL package crew cab, air lift air bags, remote start, CFM intake elbow.
ChrisSheerman is offline
post #2 of 11 (permalink) Old 04-22-2010, 03:34 AM Thread Starter
so does this mean all you guys just tighten everything up tight as possible why cant I get a lillte help for this the guys at diesel stop did'nt give me any help either. my manual I have does'nt tell me it just says to bring the truck to a garage cause you need a special press
post #3 of 11 (permalink) Old 04-22-2010, 04:34 AM
Mod Friendly Title
Zaairman's Avatar
Effing tight is the correct torque.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #4 of 11 (permalink) Old 04-22-2010, 01:42 PM Thread Starter
Great glad someone could give me a hint. Probly be doing them new weekend the ball joint tool is still on order from the parts store. Hoping I can reuse the hub seals those things are pricey enough 54 buck each!?!?
post #5 of 11 (permalink) Old 04-22-2010, 02:12 PM
Banned
You might find the info your looking for in here..
https://thedieselgarage.com/forums/showthread.php?t=140
wastedwagesracing is offline
The Following User Says Thank You to wastedwagesracing For this addition to TDG:
ChrisSheerman (04-23-2010)
post #6 of 11 (permalink) Old 04-23-2010, 03:38 PM Thread Starter
That is great help. do you think this is the torque for the ball joint nuts??
Drag link to pitman arm nut.................148 ft-lb
Thanks again. Some time next week the ball joint tool should come im then I can get my new moog joints in.
post #7 of 11 (permalink) Old 04-23-2010, 03:46 PM
Trip's Avatar
Lower ball joint nut 204 Nm (150 ft. lbs.)
Upper ball joint nut 94 Nm (69 ft. lbs.)
WALNUT (anti-ACORN) member#23
Trip is offline
The Following User Says Thank You to Trip For this addition to TDG:
ChrisSheerman (04-24-2010)
post #8 of 11 (permalink) Old 04-24-2010, 04:01 AM Thread Starter
Trip you are the man. I cant believe it was that hard to get simple numbers from someone the chart was great but didnt just say ball joint and torque numbers. I'm surprised that they are different torque specs. Glad you told me. Where do you guys get these kinda answers if not here do you call the dealer. mines pretty good but dont know if they would tell me. Thanks again everyone for the help.
post #9 of 11 (permalink) Old 04-28-2010, 03:03 PM
Curmudgeon
TooManyToys's Avatar
Not so fast.
Originally Posted by ChrisSheerman View Post
.... I'm surprised that they are different torque specs. .....
Don't do ball joints often, eh?
Check the instructions that come with what ever manufacturer is of the parts. Some companies use different torque values depending on the construction of the ball joints. And follow the torque sequence noted in the instructions as this can effect binding, causing return to center and wandering issues.
Jack -
Formerly FMTRVT, Manager of Vehicle Testing - Brakes
2003 F-350SC Lariat 4x4 6.0L Auto
Truck Modifications as below in Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is offline
post #10 of 11 (permalink) Old 04-28-2010, 03:43 PM
Trip's Avatar
next post
Trip is offline
Ball Joint replacement Diesel Duo 2003-2007 6.0L Power Stroke 8 06-15-2009 07:37 PM
Ball Joint help Snowaholic 5.9L Cummins (2003-2007.5) 0 03-13-2009 06:11 PM
Ball Joint Help.... 99fordtruckguy 1994-2003 7.3L Power Stroke 7 02-17-2008 04:25 PM
ball joint? bisket General Ford Truck and Excursion 6 01-29-2008 11:01 PM
Ball joint ????? Diesel Dog General Ford Truck and Excursion 9 06-27-2006 04:25 AM
