Forged Wheels vs Powder Coat vs 400* - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TexasTruck, this thread has received 6 replies and been viewed 3216 times.
post #1 of 7 (permalink) Old 04-25-2010, 02:12 PM Thread Starter
TexasTruck's Avatar
Images: 1
Question Forged Wheels vs Powder Coat vs 400*
Hello... I have a set of forged centerline wheels that I'm thinking about powder coating. I understand that a 400* oven is used to bake/melt the powder to the wheel. I'm concerned about the temperature weakening the wheel. I called centerline and my local powder coating facility and both said it's no problem. Of course they'll say that
Will they be ok or will I be weakening the metal?
TIA....
2008 Silver CC FX4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness
TexasTruck is offline
post #2 of 7 (permalink) Old 04-26-2010, 01:41 PM
TDG Mafia Member#67
6L strokin's Avatar
aluminum doesnt melt until like 1100 degrees or something like that i think... theres been no tellin how many people get things powdercoated and a lot of industrial places get stuff powdercoated so im sure it doesnt weakin things up any...
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
The Following User Says Thank You to 6L strokin For this addition to TDG:
TexasTruck (05-10-2010)
post #3 of 7 (permalink) Old 04-27-2010, 05:46 PM
rod.10853's Avatar
TIA....
I've been thinking about powder coating some polished aluminum wheels, too. So, I've done some research on powder coating and found some sources stating that the heat of the oven will cause the metal to "gas off" and also will "microscopically" weaken the metal. According to one article I read it stated that the wheel should be gradually heated to like 200 deg and then the powder should be applied ... this helps avoid the gas off gases from bubbling the powder coat ... and then the wheel should be slowly taken up to 400 deg and then very slowly taken down through the cooling process. So, I talked to some local powder coating places about this and they acted like I was crazy.
Additionally, according to the "crazy" article, sand blasting the wheels with sand will microscopically weaken the structure of the wheels. Therefore, it was said to use peanut shells or some other "soft" type material. My local powder coat guy said he would just scotch guard mine ... but he laughed about the temp control thing ...
With all this said, tons of guys have their wheels powder coated and are doing fine it seems.
Rodney
08 F250 CC LWB 4x4 PSD, 6 SPD-Manual, 3.73 LS
2.5" Leveling Kit / 2" Superlift Add-a-Leaf
18" MT Classic II Wheels / 35" Toyo MT Tires
Go Industries Rancher Grille Guard
SnugTop Truck Cap/Shell
Xtreme Liner
rod.10853 is offline
The Following User Says Thank You to rod.10853 For this addition to TDG:
post #4 of 7 (permalink) Old 04-29-2010, 02:30 AM
i have been working in a powdercoating shop for 2 and a half years.... you will have absolutely no problem with your wheels weakening. we have aluminum spindles, wheels, tranny housings, etc. off off desert vehicles in the oven all the time, absolutely zero problems or complaints...... both my off road trucks and ATV which take serious beatings were powdercoated.... dont worry man powdercoat them *****ezzz
DezertJunky92 is offline
The Following User Says Thank You to DezertJunky92 For this addition to TDG:
post #5 of 7 (permalink) Old 04-29-2010, 10:42 PM
Haulin' Hay
NCfarmboy's Avatar
I totally agree w/ Desert Junky -- We install and fabricate specialty architectural products-- many of them structural that are powdercoated. Powdercoat is some awesome stuff.
NCfarmboy is offline
The Following User Says Thank You to NCfarmboy For this addition to TDG:
post #6 of 7 (permalink) Old 05-01-2010, 12:57 AM
you will do more "microscopic" damage with a scotch brite pad on aluminum than 400 degrees of heat and a light sandblasting. We sandblast wood cabinets at my work....u just adjust the air pressure according to the material you are working with. Nobody should worry about powdercoating there stuff.
post #7 of 7 (permalink) Old 05-27-2010, 06:40 PM
DragStriptoMudPit's Avatar
I'M OUT!
I agree.
2008 F250 CC 4x4
8" Fabtech
20" XD wheels 38" Toyo Open Country M/Ts
Spartan 275 (310, 345, and TCM soon with Suncoast)
Bilstein all around
Northern Tool toolbox
5" MBRP SS exhaust
FX4 Grille
Custom 4" hole in bed
13.8 @ 98mph Gilliam Race Track. Beat a 07 GT 500 in the process. (Had he been a better driver maybe not, but its all about who gets there first.)
1995 Ford F150 351ci 236k miles. Still rollin hard
2000 Dodge 1500 360ci 140K miles. My Play toy
(ol ladies ride)'96 Accord 230k miles hoping to get a 2010 Raptor
Texas Club #1
Singles Club #262
B.O.M.B. Squad #80
American Club #44
Awaiting delivery/Install(Icon 4.5" Lift, Dynatrac ball joints, Harley Headlights, OEM Radius arms, 35" Mickey T's ATZs, Pioneer AVIC, Pioneer shallow mount sub, sbl2ksound 12" box, TCM w/310,Rudy's Downpipe and 5" Delete pipe, FarmboyFab Traction Bars, and some more goodz.)
DragStriptoMudPit is offline
Keep rims as is or powder coat black? Bcarriveau The Polling Place 26 04-28-2010 11:26 AM
Pics till the powder coat gets back Blk350on20s 2008-2010 Body & Suspension 12 04-13-2010 03:15 AM
Before and after the powder coat Blk350on20s 2008-2010 Body & Suspension 16 04-08-2010 05:44 PM
Can I powder coat the hot pipe from turbo to intercooler? THEPISTONHEAD 2003-2007 6.0L Power Stroke 20 02-20-2008 03:43 AM
Powder Coat blingage installed Dalpilot 2003-2007 6.0L Power Stroke 35 03-21-2006 11:38 PM
