Steering Box bad ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by KTMHauler, this thread has received 2 replies and been viewed 929 times.
post #1 of 3 (permalink) Old 05-05-2010, 08:26 PM Thread Starter
Dirt biker
KTMHauler's Avatar
Steering Box bad ?
I have a 06 E 350 and it steers weird it has been to the alignment shop 4 times and they now tell me the box is bad ?
It turns great in the turns but when you go straight it's two hands on the wheel to keep it on the road
There is no free play in the wheel
If you make a U turn and loosen up grip on the wheel it will almost come
back to center and still keep turning I have to put it back to center
The steering it kinda tight going straight
I have been Googling it and found someone else with the same problem
I believe it is the same box as the Excursion
Do you think there is a bunch of bad box's out there?
I would hate to go buy one and it still steers like this
Things i say up here
KTMHauler is offline
post #2 of 3 (permalink) Old 05-06-2010, 06:02 PM
HalfAst Racing
skippy's Avatar
Images: 1
id say check your ball joints before going for the box,it may not do it in the air when the ball joints are unloaded.also most boxes have a tension adjustment on them that determines how loose they are.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
post #3 of 3 (permalink) Old 05-06-2010, 07:19 PM Thread Starter
Dirt biker
KTMHauler's Avatar
I am also thinking that the previous owner was farting around with the screw
on top of the box trying to remove some play out of the wheel and it's a little
tight
Steering? teamsween21 Duramax 2001-2004 (LB7) 5 07-13-2009 08:13 PM
ORU Steering! Big Bad Stroker 1994-2003 7.3L Power Stroke 5 04-11-2007 12:40 AM
steering Tornsteel General Ford Truck and Excursion 1 10-12-2006 03:08 PM
Steering & Steering Pumps sredish 2003-2007 6.0L Power Stroke 7 10-10-2006 01:48 AM
x-over steering powerstroketd General Ford Truck and Excursion 1 01-16-2006 05:16 AM
