Will 305/325s fit on factory 17s on a 2005 SD? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bcarriveau, this thread has received 7 replies and been viewed 1050 times.
post #1 of 8 (permalink) Old 05-06-2010, 03:00 AM Thread Starter
********* and Mafia #90
Bcarriveau's Avatar
Wonder if the 305/70/17s or the 325/70/17s fit on my fatory 17s ? I just dont get how their approved rim collom is set up? why are there 3 numbers and one is in ()?
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #2 of 8 (permalink) Old 05-06-2010, 07:04 AM
S10
Built not bought...
Smallest on left, ideal size rim in middle, largest on right maybe. Thats kinda how I always took it.
S10 is offline
The Following User Says Thank You to S10 For this addition to TDG:
Bcarriveau (05-06-2010)
post #3 of 8 (permalink) Old 05-06-2010, 12:50 PM Thread Starter
Bcarriveau's Avatar
Now i just need to find out how wide my rims are . their 8 or 8.5s?
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #4 of 8 (permalink) Old 05-06-2010, 06:38 PM
Normally the one in () or in the middle is the width rim that the tire measurements were based on. A narrow rim makes the tire taller ect...
tucker330 is offline
post #5 of 8 (permalink) Old 05-07-2010, 07:22 AM
S10
Built not bought...
Either of the tires u had listed will fit ur stock wheels. But will prob rub alittle on the radius arm. Not a big deal though. I had the same 17s as in your avatar on my 05 single cab when it was still stock... Nothing like the look of a single cab.
S10 is offline
post #6 of 8 (permalink) Old 05-07-2010, 10:49 AM
strawboss's Avatar
Bill I've got 315's on my twuck, And I drive it like I stole it, minimal roll over...
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
post #7 of 8 (permalink) Old 05-17-2010, 12:03 AM
Senior Member, on a stick
boggerman's Avatar
I have 305/65-18 BFG's on my truck with the 2" leveling kit (on aftermarket 18x9 4.5 backspace wheels) and I think it's just right. The 35/12.50's I had before required a little massaging of the inner fenders not to rub, but the 305's fit just fine. FWIW, I think the 325's are too wide for stock wheels and you'll wear the centers out of the tires faster.
'05 F350 Amarillo CCSB FX4, Skyjacker 2" coils, 18x9 Moto Metal 951's, 305/65-18 BFG AT K/O's, Bilsteins, Skyjacker dual stabilizers
SCT XCAL3 from Elite Diesel, AEM Brute Force Dry Flow, semi-Zoodad, Steveracer mod, CCV reroute, RCD EGR delete, Autometer Ultralites on the A-pillar
MBRP Turbo-back.
Can you keep up?!?!
Well punk, can ya??
boggerman is offline
post #8 of 8 (permalink) Old 05-17-2010, 06:36 AM
Slow 6.0
i have 325 60 18s on my stock 18x8s. they fit. im not sure if the 17" stock wheels are 8" wide tho, if they are 7s i wouldnt go with a 325. after my tires are worn out i am going back to the stock size. mine are D range and with the wide tire on a narrow rim the truck doesnt drive that great. its ok unloaded, can still feel the weak sidewalls. towing can be scary at times.
2006 F350 XLT 4x4
SICKS-O is offline
FS..... 2005 Factory/OEM suspension with FX4 Rancho Branded Shocks vrsc Ford Parts 5 04-20-2010 08:31 PM
FS. 2005 OEM/Factory single disk CD radio and 5x7 speakers vrsc Ford Parts 3 04-03-2010 05:15 PM
WTB 2005+ Factory 20" Wheels Sandbox Ford Parts wanted 2 12-07-2009 07:30 PM
2005-2007 Factory Harley headlights fine69 Whats Been Sold 6 05-10-2009 03:39 AM
2005-2007 F-250/F-350 factory 20" 5-spoke wheels rtm038 Whats Been Sold 0 09-12-2007 02:37 AM
