Beep-------Beep - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by S04X, this thread has received 2 replies and been viewed 746 times.
post #1 of 3 (permalink) Old 05-31-2010, 05:21 PM Thread Starter
Beep-------Beep
I drive a 2004.5 Excursion EB. The horn is hanging or getting stuck when you try to use it. Not every time but it's becoming more frequent. So far I have been able to get it stopped by (doing the first thing I learned in mechanical and electrical applications) beating the heck out of it. I am sure it is going to stick and not quit at some inopportune time. Has anyone else had this problem and what is the procedure for repair. I'm not looking forward to working around the airbag. Thanks in advance
S04X is offline
post #2 of 3 (permalink) Old 05-31-2010, 05:43 PM
bushpilot's Avatar
admittedly i dont know if the SD has TWO horns ore one...
when the horn "sticks" is it a single tone or duel <could be a sign of
just ONE horn sticking>.
if BOTH tones/horns are sticking then id replace the horn RELAY
Don R.
Truck Audio,
bushpilot is offline
post #3 of 3 (permalink) Old 05-31-2010, 06:38 PM
HalfAst Racing
skippy's Avatar
Images: 1
there are two horns,located between the fender and the inner fender on the passenger side.id lean towards the relay being the issue,or possibly the contacts of the horn switch behind the air bag.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
The Following User Says Thank You to skippy For this addition to TDG:
bushpilot (06-01-2010)
