2001 F-450 Brake problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by msherrilljr, this thread has received 0 replies and been viewed 2092 times.
post #1 of 1 (permalink) Old 05-15-2011, 07:51 PM Thread Starter
Installed a new caliper on the rear. Basic stuff. Finish up and bleed the entire system the old way. Pump hold...crack open bleeder valve let fluid/air bleed out.....tighten valve before release pedal. Done this over starting with the caliper fartherest away from reservoir. Pedal is still spongy. Is this one of those "ford" better idea ways of bleeding the system? What am I doing wrong? Brakes are simple hydraulics. Oh yeah............no leaks anywhere.
msherrilljr is offline
2001 IDM Problem!!!! jerryjust 1994-2003 7.3L Power Stroke 6 05-18-2012 04:11 PM
2001 7.3l No start Problem Sometimes ButlerValley 1994-2003 7.3L Power Stroke 7 04-27-2010 11:47 PM
2001 5.9 ECU problem pjw 5.9L Cummins (1998.5-2002) 3 12-18-2009 06:47 PM
2001 2500 4x4 Rear Drum to Disc Brake Conversion and other mods? 6thFrame 5.9L Cummins (1998.5-2002) 4 01-07-2008 11:28 PM
2001 npr trans problem burkeftm Medium and Heavy Duty 1 06-14-2007 10:04 PM
