Driver side window tsb - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by thaefele, this thread has received 7 replies and been viewed 3104 times.
post #1 of 8 (permalink) Old 01-04-2009, 03:52 AM Thread Starter
does anyone have the driver side window tsb or know anything about it? I have seen something about it but I can't find it again. thanks
thaefele is offline
post #2 of 8 (permalink) Old 01-04-2009, 02:03 PM
fordsuperduty01's Avatar
This one?
TSB 08-11-5
06/09/08
POWER WINDOW NOISE - BUILT BEFORE 7/31/2007
FORD:
2008 F-Super Duty
ISSUE
Some 2008 F-Super Duty vehicles built before 07/31/2007 may exhibit a power window that is noisy. The noise is due to the spring in the window regulator assembly.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Replace the Window Regulator per Workshop Manual, Section 501-11.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
081105A 2008 F-Super Duty: 0.6 Hr.
Replace The Window
Regulator, Includes Time
To Remove Interior Door
Trim Panel May be
Claimed With Operations C
Or D To Cover Necessary
Repairs: One Front Door
(Do Not Use With 23943A,
23943A10, 27406B,
27406B8)
081105B 2008 F-Super Duty: 1.0 Hr.
Replace The Window
Trim Panel May be
Repairs: Both Front Doors
23943A10, 27406B,
27406B8)
081105C 2008 F-Super Duty: 0.7 Hr.
Replace The Window
Trim Panel May be
Claimed With Operations A
Or B To Cover Necessary
Repairs: One Rear Door
23943A10, 27406B,
27406B8)
081105D 2008 F-Super Duty: 1.4 Hrs.
Replace The Window
Trim Panel May be
Repairs: Both Rear Doors
23943A10, 27406B,
27406B8)
DEALER CODING
CONDITION
BASIC PART NO. CODE
2523200 42
2005 F-250 6.0L King Ranch FX4. 125k miles, Edge Platinum, EGR delete, MBRP turbo back exhaust without cat, an 03 turbo, and 4.30 gears.
A.S.E. Master certified automotive and light duty diesel technician.
fordsuperduty01 is offline
post #3 of 8 (permalink) Old 01-04-2009, 02:05 PM
Or this one?
TSB 07-10-5
05/28/07
FRONT DOOR SIDE GLASS SCRATCHED DUE TO
COLLECTION OF DIRT/DEBRIS IN WARPED OUTER
WINDOW MOLDING
FORD:
2003-2007 Expedition
2005 Excursion
2005-2008 F-Super Duty
LINCOLN:
2007 Navigator
This article supersedes TSB 06-18-2 to update the vehicle model years, vehicle application and parts information.
ISSUE
Some 2005-2008 F-Super Duty, 2005 Excursion, 2003-2007 Expedition and 2007 Navigator vehicles may exhibit outer window molding weather strip assembly warping around the lower front window channel. The condition may be described as a warped or loose outer window molding. There may be a pucker or gap between the window beltline molding weather strip assembly and the window glass. This may result in dirt and debris collecting between the molding and the glass, and therefore scratching the side-window glass.
ACTION
Use the Service Procedure to replace the outer window molding and adjust the molding flange.
SERVICE PROCEDURE
1. Lower the side door window completely.
2. Remove the outside mirror.
3. Remove the outer window molding weather strip assembly by lifting it up away from the flange (Figure 1).
4. Raise the side door glass completely.
5. Measure the distance from inboard sur[ace of the door molding flange to outboard surface of the window glass (Figure 2). Distance from flange to glass should be between 5/8-3/4" (16-19 mm) for F-Super Duty and Excursion, and 3/16-7/16" (5-11 mm) for Expedition and Navigator.
6. Lower glass completely.
7. Adjust the door molding flange to meet the 5/8-3/4" (16-19 mm) dimension. Do not adjust flange more than 3/4" (19 mm) away from the glass.
8. Install a new lower window molding weather strip assembly.
9. Reinstall mirror.
10. If the side door glass has been scratched, replace the glass. Refer to Workshop Manual, Section 501-11.
Parts Block
071005A 2005-2008 F-Super Duty, 0.5 Hr.
2005 Excursion: Replace
The Window Beltline
Molding Includes Time To
Measure And Adjust Door
Molding Flange One Front
Door (Do Not Use With
17628B, 17682C, 23943A,
23943B, 23943A14,
18808AF, 17682B)
071005B 2005-2008 F-Super Duty, 0.9 Hr.
The Window Beltline
Molding Flange Both Front
Doors (Do Not Use With
23943B, 23943A14,
18808AF, 17682B)
071005C 2005-2008 F-Super Duty, 0.7 Hr.
The Window Beltline
Molding Flange, And
Replace Window Glass:
One Front Door (Do Not
Use With 17628B, 17682C,
23943A, 23943B,
23943A14, 18808AF,
17682B)
071005D 2005-2008 F-Super Duty, 1.3 Hrs.
The Window Beltline
Molding Flange, And
Both Front Doors (Do Not
23943A, 23943B,
23943A14, 18808AF,
17682B)
071005E 2003-2007 Expedition, 0.6 Hr.
2007 Navigator: Replace
The Window Beltline
Molding, Includes Time To
Molding Flange: One Front
17682C, 21452A, 23943A,
23943AB, 23943A14,
18808AF, 17682B)
07100SF 2003-2007 Expedition, 1.1 Hrs.
The Window Beltline
Molding Flange: Both Front
23943AB, 23943A14,
18808AF, 17682B)
071005G 2003-2007 Expedition, 0.9 Hr.
The Window Beltline
Molding Flange And
Use With 17682C, 21452A,
23943A, 23943AB,
23943A14, 18808AF,
17682B)
071005H 2003-2007 Expedition, 1.7 Hrs.
The Window Beltline
Molding Flange And
23943A, 23943AB,
23943A14, 18808AF,
17682B)
The Following User Says Thank You to fordsuperduty01 For this addition to TDG:
gporter302 (01-05-2009)
post #4 of 8 (permalink) Old 01-05-2009, 02:23 AM
I know my front windows are scratched and the rear ones to. I have the tinted windows from Ford. Has anybody had the dealer replace their windows under this tsb?
Thanks
Greg
2008 F-250
Stock. Hoping one day to get the spartan.
Out of work?
Hungry?
Why dont you eat your rice burner!!!!
gporter302 is offline
post #5 of 8 (permalink) Old 02-02-2009, 05:28 PM
2007 Navi with Window TSB issue
Thanks
Greg
My NAVI is at Ford right now. They called me to let me know that because the scratches on the driver side and passenger side windows are not vertical they cannot conclude that the issue was caused by this TSB. I find this incredible ! The scratches do move laterally across the window to some degree. If the rubber blade is wrapped I imagine that dirt can travel if it is loose? Any one have the same issue?
4coolkid is offline
post #6 of 8 (permalink) Old 02-02-2009, 05:33 PM
bushpilot's Avatar
bummer, my drivers side just started makin' the SPRING noise !
Don R.
Truck Audio,
bushpilot is offline
post #7 of 8 (permalink) Old 02-03-2009, 02:01 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
I have only EVER seen the noise that this TSB is talking about on a few of the early 08s. And it is an awful noise not just a little noise.
2003 F250 "Pulling Truck"
hhrecovery is offline
post #8 of 8 (permalink) Old 02-03-2009, 11:41 AM
bushpilot's Avatar
mines making a strange creeking noise...not a scraping (like scratch)...
and its way low in the door...i really dont wanna pull the freeking door panel
<AGAIN>...ive got all that damm HUSH MAT on the door...pain to cut
thru it and re-apply it (ill look like a patch work quilt) !
Don R.
Truck Audio,
side menu 7.3 4x4 power The Parking Lot 1 12-29-2008 07:58 PM
LLY Intake Manifold Replacement - Right Side (LBZ, LLY) ripmf666 GM Spec Info 0 12-28-2008 11:35 AM
New (last June) TDG member, fairly new MDT, and very old driver! ernesteugene Introductions 12 12-27-2008 07:16 PM
01-08 Cylinder Head Replacement - Right Side ripmf666 GM Spec Info 0 12-27-2008 03:22 AM
DashDaq - Driver Error/Ford Parameters mick1955 2008-2010 6.4L Engine Tuner Forum 1 12-23-2008 02:28 PM
