Diy intake for 7.3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by camojeeper, this thread has received 12 replies and been viewed 44416 times.
post #1 of 13 (permalink) Old 12-24-2008, 05:24 AM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
Diy intake for 7.3
TO DO A DIY INTAKE FOR THE 7.3 LTR POWERSTROKE
you will need a 6637 air filter avaiable from napa auto parts and cheper from fleet filter you will need 7" of 4" exhaust pipe for a 94-97 and 4" of 4" exhaust pipe for a 99-03 sd
loosen hose clamp @ your factory air box then remove the air box carefull to remove the air temp sensor then lay it near the fender. then remove the air box/filter assy all the way remove the gromets from the air filter gauge/air temp sensor now toss old air box across the shop! then set your new filter/pipe set up into place and renstall both hose clamps. ta da your done go out and enjoy your new air intake
on edit if you want to put in you airfilter gauge drill an 11/16" hole into the pipe and for the air sensor it was just larger than 7/16" you may have to wollow out the hole a bit for a tight fit
tools needed
11/16 & 7/16 drill bits
10 mm socket
7/16" socket
prybar
5/16"/8mm socket/driver
parts needed
1 #6637 air filter
1 4.5-5" hose clamp
1 4-7" piece of exhaust pipe( if using other than stainless steel paint the inside so it wont rust) 4" SDR 35 sewer plastic pipe is a great pipe also
Optional Parts
a magic smoke performance pre filter cover
or one of petes filter covers
[email protected]
[email protected]
for those of you that feel this is above your skill level or dont have the tools to build it please pm me and i will do what i can to help
steve
ID:	135   Click image for larger version
Name:	red yellow blue filters.jpg
ID:	136   Click image for larger version
Name:	under hood 2.jpg
ID:	138   Click image for larger version
Name:	under hood 3.jpg
STEVE TDG MAFIA#106
camojeeper is offline
The Following User Says Thank You to camojeeper For this addition to TDG:
gardentractor (01-15-2009)
post #2 of 13 (permalink) Old 01-01-2009, 06:34 PM
Truck pullin' S.O.B.
OffKilter's Avatar
Images: 13
did you see any difference with this set up it looks like it would get alot of heat off the engine.
1999 F-250 Lariat, Red, Super Cab, Short Box, 6.8L V-10
2003 F-350 XLT Regular Cab Long Box 6.0L 6-speed, tinted windows, push bar, 4inch MBRP exhaust, Edge Juice w/ attatude.
1969 F350 "The Shillelagh" future pulling truck, 428ci, 4-speed, 4:10 gears.
OffKilter is offline
post #3 of 13 (permalink) Old 01-01-2009, 07:20 PM
TDG Mafia Member#67
6L strokin's Avatar
im thinkin about doin a DIY intake for my 6.0....anybody ever done one?
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #4 of 13 (permalink) Old 01-05-2009, 09:47 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
heat is not an issue because the intercooler will cool the air flow within a few degres of ambient temp and i saw a noticeable change in smoke of the line and more power also got 1 mpg better over a k&n drop in filter
STEVE TDG MAFIA#106
post #5 of 13 (permalink) Old 01-05-2009, 09:48 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
one is in the works but not fineshed yet
STEVE TDG MAFIA#106
6L strokin (01-06-2009)
post #6 of 13 (permalink) Old 01-06-2009, 02:18 PM
TDG Mafia Member#67
6L strokin's Avatar
sweet! i was just gona get my buddy to help me figure out how to plumb it up....best to use pvc or exhaust pipe? I appreciate the info!
Previous Rides:
post #7 of 13 (permalink) Old 01-06-2009, 06:37 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
pm sent
STEVE TDG MAFIA#106
post #8 of 13 (permalink) Old 01-09-2009, 02:07 PM
OffKilter's Avatar
Images: 13
That must be less smoke right?
post #9 of 13 (permalink) Old 01-11-2009, 06:38 PM Thread Starter
MAFIA MEMBER 106
camojeeper's Avatar
ya less smoke more go off the line it doesnt smoke as much and the turbo is lightin up way faster. of course it will smoke on the higher tunes but not as much as when i had the k&n drop in
STEVE TDG MAFIA#106
post #10 of 13 (permalink) Old 01-21-2009, 12:53 PM
Bolt
gardentractor's Avatar
Man!!!!I wish i would have done this mod earlier!!!!! thi was the eaisest mod ive done yet and it helped big time!!!
2000 F350 4X4 Powerstroke red 6spd reg cab stock for now...
1988 Chevy IROC-Z camaro black 5spd 305 55,000 orig miles, my baby
1988 Chevy 4x4 350 ext long bed
1980 Gmc 4X4 modified 350 k20 flatbed 4spd
1956 6400 Chevy 235 6 cyl
gardentractor is offline
The Following User Says Thank You to gardentractor For this addition to TDG:
camojeeper (01-22-2009)
6.4L AFE Stage 2 Intake Install Sledpuller500 2008-2010 6.4L Power Stroke 28 01-12-2009 02:45 AM
Banks Intake TreverAdamo 2008-2010 6.4L Engine Tuner Forum 13 12-24-2008 03:22 AM
