96 F-350 info - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ole JIM, this thread has received 1 replies and been viewed 1333 times.
post #1 of 2 (permalink) Old 02-07-2009, 09:45 PM Thread Starter
96 F-350 info
iNFO WANTED--how much of a JOB is it? to remove & re-Install new front fenders--& what Panit? do you guys suggest? in painting the inner fender--before installation--Thanks in Advance--Ole JIM--
Ole JIM is offline
post #2 of 2 (permalink) Old 02-08-2009, 01:40 AM
Images: 3
Takes some time...
1 bolt under the carpet on the floor of the cab, per side. Around the brake pedal area, pull the carpet or mat up and you'll see the plug in the floor.
2 bolts at the base of the hood, per side.
2 or 4 bolts on the core support, per side.
I think I got them all...
Gotta remove the whole front end, lights, grille, header panel, which is an easy job.
Gotta take off the bumper filler also, the bumper should come off too to make the job easier, but isnt needed.
Gotta take all the stuff off the inner fenders, and tie them up somewhere, including batteries and trays etc.
Then remove the inner fenders.
The Core support can stay.
The job isnt exactly hard, just need the time to do it.
Here are some pictures with the inner fender removed.
As far as Paint, for the inner fenders? Sand them, prep them, paint with a plastics or vinyl paint, like dupli-color interior paint. Or prep them, and get plastic primer, and paint with auto paint.
1995 F-250HD XLT. 7.3L, E4OD. TW 6 Position chip, K&N Intake--Tymar 3x4" DP--5" straight piped--36"x5" Miter Stacks--Rebuilt Trans--Trans-Go Tugger--Turbo Timer--Autometer Pyro, Trans, Boost guages in A-pillar--Cervini's Cowl Hood--Buckstop Bumper, and LOTS MORE!
Dana 60 Swap STILL in progress...
2003 Ford Mustang Cobra, Gotta love being blown!
1993 Ford Lightning, My 393ci Sleeper
weareweird69 is offline
need info longford Medium and Heavy Duty 8 08-09-2007 12:54 PM
need 7.3 info Joey Boombotts 1994-2003 7.3L Power Stroke 6 07-30-2007 01:22 PM
info please hyper08 Ford Oasis requests 1 07-19-2007 03:39 AM
12V info diesel_ram_man 5.9L Cummins 12 Valve (1994-1998.5) 4 11-05-2006 05:19 AM
VSS Info ymmot 2003-2007 6.0L Power Stroke 3 02-16-2006 07:21 AM
