Need help wiring upfitter sw in a 09 F350 diesel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sunruner19, this thread has received 5 replies and been viewed 2820 times.
post #1 of 6 (permalink) Old 03-29-2009, 07:26 PM Thread Starter
Images: 2
I want to install the upfitter switches in my 09 f350. Purchased the switches and wiring from a ford dealer who has no clue as to wiring them in my truck, nor will provide me with a wiring diagram. The main connector is grey with 6 wires. I searched under the dash for the connection and also the fuse panel in the right kick panel with no luck Can anyone help me here?
sunruner19 is offline
post #2 of 6 (permalink) Old 03-30-2009, 08:46 PM
Strokin05's Avatar
Now I am not sure if they changed them from the 05-07 trucks, but on those, you had to pull the glove box down (depress the two tabs) and the box mounted right there, Then for the wiring, run the harness to the fuse box, under the dash (you will have to pull it out) and it will plug in on the back side of it. There should be an open slot. You will need a 10mm socket to get the fuse box out. Hope this helps.
Strokin05 is offline
post #3 of 6 (permalink) Old 03-30-2009, 08:49 PM
Strokin05's Avatar
They may have changed how they run it, and they may not have. I know on my 03 I mounted it, and ran it just like I did on my dads 05. I found this link for the older trucks, may explain it better than I did.
http://www.powerstrokedatabase.com/read.php?id=147
Mike
post #4 of 6 (permalink) Old 03-30-2009, 10:49 PM Thread Starter
Images: 2
I found the correct bulletin from Ford concerning the 08-09 upfitter install. It is not the same as the 05-07.
https://www.fleet.ford.com/truckbbas/non-html/q157.pdf
post #5 of 6 (permalink) Old 05-31-2009, 06:47 AM
need a post count to view the links =]
kalis is offline
post #6 of 6 (permalink) Old 05-31-2009, 06:47 AM
dfhdfhfhfshfshsfhs
kalis is offline
08 F350 wiring diagram 737tdi 2008-2010 6.4L Power Stroke 2 03-13-2008 03:31 PM
help with type of diesel fuel for 96 F350 Jay 1994-2003 7.3L Chips & Tuners Forum 3 10-20-2007 07:25 PM
upfitter switch wiring imported_JDeere5105 2003-2007 6.0L Power Stroke 9 09-09-2007 06:12 AM
Tail light wiring for 08' f350 sd srw bludragon 2008-2010 6.4L Power Stroke 4 07-21-2007 06:56 PM
08' f350 sd lariat in las vegas new to diesel bludragon Introductions 10 05-15-2007 03:03 AM
