2009 High Idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by speckfisher, this thread has received 2 replies and been viewed 1088 times.
post #1 of 3 (permalink) Old 07-02-2009, 12:46 AM Thread Starter
2009 High Idle
Does anyone know if the high idle to the upfitter switches works on the 09 the same as the 07. Are the wire colors the same?
speckfisher is offline
post #2 of 3 (permalink) Old 07-03-2009, 02:17 AM
Smokin
fordfanatic69's Avatar
It does work but you can only use the pto wire the other way will not work tried both and the only one that works is the pto wire. Don't remember what color but it is labeled under the drivers side. I will check the color for you.
09 F250 Crew Cab FX4
5% tint 35% whole windshield w/5% brow
4" lift
35X12.50R20 Toyo
Under cab Lights
Bed Lights
5" Flow Pro No Muffin W/6" tip
Spartan 310
fordfanatic69 is offline
post #3 of 3 (permalink) Old 07-04-2009, 04:48 AM Thread Starter
Thanks
Skweeker Mod (High Idle or Aux. Idle) CBSuperduty Ford - Modification instructions, Product installs and Tech Articles 23 12-31-2009 03:22 AM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
high idle ssd79 2003-2007 6.0L Power Stroke 8 11-15-2007 07:54 AM
High Idle & 3 Cylinder Idle Mopar1973Man 5.9L Cummins (1998.5-2002) 11 11-02-2007 01:44 AM
6.0 high idle? bobo 2003-2007 6.0L Power Stroke 23 12-01-2005 12:11 AM
