Cheap fix for body bushings - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 5 replies and been viewed 1728 times.
post #1 of 6 (permalink) Old 12-16-2009, 05:09 PM Thread Starter
My dually needs body bushing and I cannot afford a new bushing kit right now. Normally I would just wait until I could, but this truck has to be on the road as soon as possible. So, I started digging around to see what I could find. I sent many of these polyurethane bushing home while I was in Iraq. They were getting thrown away and I knew I could use them here. I am not saying this should be a permanent fix, but it does work out well if you are on a budget. I used a collar inside the bushing so they will do their job and not just get crashed. I also used a washer that fit the six sided hole in the body mount then drilled it out to fit the collar. So it all interlocks nicely. The new bushings are a bit taller than the old but not by much and I think they would be the same height as new ones any way. I know using the correct store bought parts is a much better way to go and I intend to do just that once we get back on out feet. But I figured this tip might help some of you out there in case you have a similar problem.
EDIT:
I know the paint on the frame looks like ***, but without the proper prep tools and materials I am lucky it turned out at least that good. That will get blasted and looking good during stage two of this build later on.
ID:	23720   Click image for larger version
ID:	23721   Click image for larger version
ID:	23722   Click image for larger version
ID:	23723   Click image for larger version
post #2 of 6 (permalink) Old 12-16-2009, 05:15 PM Thread Starter
Forgot one.
post #3 of 6 (permalink) Old 12-17-2009, 12:31 AM
Looks pretty good from what I can see. Is it possible you could cut the bushing to get it closer to factory specs?
2004 6.0L F350 Lariat Auto 4x4 CC/LB/DRW - sold
Sumimoto 255/70/22.5 on American Force Classic 22.5 wheels, 4.88 w/Truetrac rear, Mag-Hytec front/rear covers, Mag-Hytec 5R110W trans pan and '08 improved filter, custom front/rear springs from National Spring, Bilstein shocks, Bilstein dual stabilizer shocks, 4" stainless turbo back to a FTE single 6" stack, ARB Snorkel intake, Dfuser coolant filter kit, CFM++ Large Mouth, Doug's custom intake manifold, Powermax turbo w/batmowheel, Warren 175/75 injectors, ARP studded, custom CCV reroute, fan shroud removed, Diehard Platinum PM-1 batteries relocated, permanently installed battery tender with front/rear plug in access, HD250 amp alternator w/remote rectifiers, (9) ISSPRO Performax gauges, Nathan K5s, Warn hidden winch bumper kit, Warn 16.5k winch, Reflexxion steel hood, Jimmijammers, Britebox, Retro Solutions, ATTA 50gal Bed tank/tool box combo, Titan 67gal main tank..Hellman sumped, custom regulated return w/Fuelab pump, 6.4 oil filter canister, AMP steps, F650 lower dash w/nine switch panel , Carling switches, SCT X2 and stuff
boobin is offline
post #4 of 6 (permalink) Old 12-17-2009, 12:36 AM Thread Starter
Not with what I have available to be. They are real close to the stock worn out bushings. I think if I installed new ones out of the box, they would be the same hight.
post #5 of 6 (permalink) Old 12-17-2009, 04:56 PM
boobin is offline
post #6 of 6 (permalink) Old 12-17-2009, 11:31 PM Thread Starter
I jst got the other side done a little while ago. It turned out nice. If I had a Jeep or a lighter body like that, I would use these for all the body mounts.
urethane bushings Bruno2 1994-2003 7.3L Power Stroke 1 12-16-2009 05:48 AM
I need bushings, but ... BillsFan 1994-2003 7.3L Power Stroke 7 11-29-2009 06:06 AM
sway bar bushings vcassens 2003-2007 6.0L Power Stroke 3 01-12-2009 02:25 AM
sway bar bushings ssd79 General Ford Truck and Excursion 8 04-02-2008 01:14 PM
Shock bushings? Audiomechanic 1994-2003 7.3L Power Stroke 4 10-12-2006 12:11 PM
