2008 F250 Leveling kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kwestermeyer, this thread has received 13 replies and been viewed 19970 times.
post #1 of 14 (permalink) Old 07-17-2010, 02:15 AM Thread Starter
Hello first off i have read the pages of these forums front and back and i see so many answers to my question but im not sure which is the correct so ill try again.
I have a 2008 F250 i currently just purchased 35" Toyo MT to go on my factory 20" rims. Now im looking at buying this kit atm
the 2.5" ready lift with the 4 inch blocks.
Now my question is i know the front has to be raised 2.5 " but do i really need to do anything to the back of the truck lift wise? I am just unsure and i dont wanna spend money on something i dont really need. Any help would be appreciated.
Kwestermeyer is offline
post #2 of 14 (permalink) Old 07-17-2010, 02:31 AM
fine69's Avatar
Most leveling kits are made to raise the front of an F350 level with the back. The reason your getting the rear block would be to raise the back of your F250, to the height of an F350. Make sense?
H-M.W.H. Club #2
Union Club #1
Singles #237
B.O.M.B. Squad #12
Ridin' Dirty Club #17
American Club #15
fine69 is offline
post #3 of 14 (permalink) Old 07-17-2010, 04:42 AM
Green Goose No Juice
Sorry, i dont want to start another thread for this, and i hope not to hijack his thread, but does $369 for a 2.5" ready lift, installation, and wheel alignment (if need be) sound in the right ballpark?
2010 F250 Lariat FX4 w/Sync.. Everything but nav and sunroof.. Little bit of IDP to help it out
WoodBoy is offline
post #4 of 14 (permalink) Old 07-17-2010, 02:13 PM
TexasTruck's Avatar
Images: 1
On the F250, yes you need a taller rear block. Otherwise the front will be higher than the back. Like fine69 said, most leveling kits are designed for the F350, which have a taller rear block than the F250. Keep in mind a rule of thumb about ubolts, when you remove them you should replace them with new ones. They aren't that expensive for the piece of mind.
Good luck!
2008 Silver CC FX4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness
TexasTruck is offline
post #5 of 14 (permalink) Old 07-17-2010, 02:27 PM
TexasTruck's Avatar
Images: 1
That sounds like a good price. Looks like you have an F250, you may want to ask if that price includes rear lift blocks and ubolts.
Good luck!
2008 Silver CC FX4
The Following User Says Thank You to TexasTruck For this addition to TDG:
WoodBoy (07-21-2010)
post #6 of 14 (permalink) Old 07-17-2010, 04:02 PM
TEXAS FIGHT
Hellraiser's Avatar
Yes, for an F250, it will to be raised if you put a Front Leveling kit (2.5")
Your options for the rear:
-f350 blocks
-purchase aftermarket rear blocks
-purchase rear bag leveling system (firestone)
-purchase rear add a leaf system (this is the route I chose)
08 F250 Ext. Cab LWB 4x4.
Hellraiser is offline
post #7 of 14 (permalink) Old 09-01-2010, 10:29 AM
Top Gunz 1 1/2 inch kit with Bilstein shocks
Top Gunz has put together a kit using Skyjacker 1 1/2 spring and Bilsteein shocks. That should be about right for a F250 running 35's right? I have bags to help level back and it also has Bilstein shocks. Any thoughts?
2008 HD F250 CCSB, Spartan, AFE downpipe back exhaust
joe22790 is offline
post #8 of 14 (permalink) Old 09-01-2010, 11:21 AM Thread Starter
http://s63.photobucket.com/albums/h1...ermeyer/Truck/
Here is my truck now I used the 2.5 inch leveling kit with 4 inch rear blocks From SST and also the 35 Inch Toyo MT.
post #9 of 14 (permalink) Old 09-02-2010, 02:03 AM
GUTTS's Avatar
wow kwestermeyer we are twins
GUTTS is offline
post #10 of 14 (permalink) Old 12-07-2011, 11:20 PM
GA Lawn Care's Avatar
35" fit stock 08 Fx4 F250??
I am about to purchase Toyo M/T 35x12.50R20.. The overall diameter is 35.0 and overall width is 13.0 I have the 20" Gear rims that were an extra option with the FX4 package when I bought the truck. The dealership gave me Goodyear wranglers that SUCK! They did give me 56K miles but nobody has been able to balance them properly. They shake like hell on the highway even with max 80 psi. and cake up as soon as I hit wet dirt. They are 34.1 overall diameter.
So anyway, will I be alright with the 35" w/o a lift? My truck sits almost perfectly level and I have seen another F250 FX4 same year "no lift" with the 35" toyo's but he had aftermarket bumpers.. Any thoughts?
GA Lawn Care is offline
DR 2.5" leveling kit 2005-2008 SD imported_keving Whats Been Sold 0 10-06-2007 12:24 PM
Questions about a Leveling kit on a 2008 SD Shawn General Ford Truck and Excursion 3 09-19-2007 12:22 PM
F250 Leveling Kit Mylesofsmyles General Ford Truck and Excursion 2 08-25-2007 04:26 AM
DR Leveling Kit 06 F250 06f250sd Supporting Vendors Forum 5 03-02-2007 11:30 PM
F250 leveling kit DBogo Supporting Vendors Forum 5 06-15-2006 03:47 AM
