Nitrogen In Tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Roach, this thread has received 16 replies and been viewed 1594 times.
post #1 of 17 (permalink) Old 09-17-2009, 05:13 PM Thread Starter
Roach
Roach's Avatar
Nitrogen In Tires
I have heard about replacing the air in the tires with nitrogen. Anyone done this, or anyone know of pro's and con's? Thanks.
2008 F-350 Lariat Dually, 4X4, Long Bed, Sirus Radio, Prestige Remote Start/Turbo Timer, Retrax Bed Cover, Power Tailgate Lock, Pillar Guages, Pyro, Boost, Trans Temp., chrome door handles, chrome fuel filler door.
Roach is offline
post #2 of 17 (permalink) Old 09-17-2009, 05:16 PM
Mostly bunk and BS. The only real advantage is the nitrogen will slow down the oxidation of the rubber material. Useless unless you keep the tires 10 years. All the rest is just hype to sell you something that is already 79% of the atmosphere. GOOGLE it..
yukondiesel is offline
post #3 of 17 (permalink) Old 09-17-2009, 05:16 PM
is here and there.
Rcannon's Avatar
Images: 11
I was reading this the other day.
http://www.thetruthaboutcars.com/the...with-nitrogen/
I guess you really need to make up your own mind on what to believe.
Rcannon is offline
post #4 of 17 (permalink) Old 09-17-2009, 05:23 PM
yup and another one
Images: 16
Send a message via AIM to Angel Bunnie
I just put Nitrogen in my tires about 6 months ago, as did my boyfriend, and so far the tires have maintained their pressure a lot better (a lot less of loss) so less air fill ups. I haven't noticed a real change in gas mileage yet, but my boyfriend says he gets better mileage from it.
Ultimately its up to you
Angel Bunnie is offline
post #5 of 17 (permalink) Old 09-18-2009, 01:04 AM
Ford F250 Dude
Jus Cruisin's Avatar
Got nitrogen in my 37's and they don't loose pressure like they did with "air". It can't hurt and it is done for free at my Ford dealer.
2008 Ford F250 4X4 Lariat Crew Cab Short Box 37x13.5x22 Toyos, KMC XD wheels, BDS 6" lift, tuned up.
Other toys:
2008 Roush 428R Mustang - Supercharged
2008 Corvette convertible
2009 Harley Davidson FLTRSE3 Road Glide
Jus Cruisin is offline
post #6 of 17 (permalink) Old 09-18-2009, 06:05 PM
Whipersnapper
battle cattle's Avatar
Time gone from Iraq!
Send a message via AIM to battle cattle Send a message via MSN to battle cattle Send a message via Skype™ to battle cattle
its not as effected by heat... thats why race cars use it.... so will it help you... maybe necessary.... no
2008 F350 DRW SB Black/Black (Spartan Tuned) SOLD
2006 BMW M3 Black/Black (Stock)
Angel Bunnie: though Russifer is a pretty little guy
Dually Club #60
battle cattle is offline
post #7 of 17 (permalink) Old 09-18-2009, 07:11 PM
Ummm--yes it is. Nitrogen is not immune to any of the laws regarding behavior of gases, the main one being pV=nRT. N2 WILL expand and contract under temperature changes, just like any other gas will.
jvencius is offline
post #8 of 17 (permalink) Old 09-19-2009, 12:50 PM
Whipersnapper
please read before you call BS
Dually Club #60
post #9 of 17 (permalink) Old 09-19-2009, 01:05 PM
Super Moderator
John_G's Avatar
No, jvencius was 100% correct, nitrogen and air respond to heat in EXACTLY the same way, there is no difference at all.
What no one has mentioned was the REAL reason race teams and aircraft use N2 as opposed to compressed air, you know the answer, but just never thought of it....
When you compress "air" and inflate a tire with it, what else is in there? (hint, you need to drain it every so often)
WATER vapor!
N2 is VERY low in moisture, and THAT is what causes the difference in heat response between N2 and "air" filled tires. With a GOOD moisture capture system, you get exactly the same results with N2 as with DRY air.
"Air" is 78% nitrogen and 21% oxygen, both molecules are effectively the same size, so your tires won't show leakage rates different with N2 than with air. In fact, it's the oxygen that leaks out because it's ever so slightly smaller. So if you lose 21% of your air (78% remaining) and you refill with 78/21 you are end up with 78% + 15% = 93% N2.
I vote for LIBERTY!
John_G is offline
post #10 of 17 (permalink) Old 09-19-2009, 03:32 PM
Whipersnapper
WATER vapor!
If that is the case... As you are saying the most technology advanced form of motorsports still requires the use of N2.....and I think they know how to change a dryer system.
It all comes down to thermal expansion for Nitrogen vs (Hydrogen, Nitrogen, Oxygen and Argon) common name Air http://wiki.answers.com/Q/What_is_th...formula_of_air
I wonder which would be more linear for expansion...
Dually Club #60
Tires ? Stroked Ford 1994-2003 7.3L Power Stroke 5 04-20-2009 09:15 PM
did anyone fill their tires with nitrogen? brietwyk General Ford Truck and Excursion 10 10-03-2007 09:17 PM
nitrogen in tires? imported_fast_and_furious General Ford Truck and Excursion 3 07-23-2007 03:41 AM
Tires! Tires! Tires! Opinions! Suggestions! Pegsmi98 General Ford Truck and Excursion 4 03-13-2007 07:16 PM
Nitrogen In Tires....Good/Bad/Ugly?? bigdraft The Parking Lot 24 07-19-2006 12:19 AM
