Back up sensors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rosco, this thread has received 8 replies and been viewed 4411 times.
post #1 of 9 (permalink) Old 09-30-2009, 12:03 AM Thread Starter
Rosco's Avatar
Back up sensors
My back up sensors shut off when I put the truck into reverse, does anybody know why this is happening?
2008 F350 White CC Lariat 6.4L "Spartan Tuned"
Rosco is offline
post #2 of 9 (permalink) Old 09-30-2009, 01:08 AM
bushpilot's Avatar
fuse ? bad ground ? dirty sensors ?
Don R.
Truck Audio,
bushpilot is offline
The Following User Says Thank You to bushpilot For this addition to TDG:
Rosco (10-01-2009)
post #3 of 9 (permalink) Old 09-30-2009, 01:08 PM
Banned
Because it's a POS system. Mine does the same, like many others do...
wastedwagesracing is offline
The Following User Says Thank You to wastedwagesracing For this addition to TDG:
Rosco (10-01-2009)
post #4 of 9 (permalink) Old 09-30-2009, 01:19 PM
O2ShootTheJ's Avatar
mine was doin it, i took it to ford and had it fixed. not sure what they did
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
The Following User Says Thank You to O2ShootTheJ For this addition to TDG:
Rosco (10-01-2009)
post #5 of 9 (permalink) Old 09-30-2009, 02:13 PM
bushpilot's Avatar
i know in the winter time folks have problems w/ the sensors from salt/snow residue build up.
Don R.
Truck Audio,
Rosco (10-01-2009)
post #6 of 9 (permalink) Old 09-30-2009, 02:47 PM
I like Pretty Girls!
Hollywood's Avatar
Mine in the winter ice up after washing the truck, but other than that they work good
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
The Following User Says Thank You to Hollywood For this addition to TDG:
Rosco (10-01-2009)
post #7 of 9 (permalink) Old 09-30-2009, 04:47 PM
Hellbilly's Avatar
My back up sensors work fine..unless I'm drinking...and then they get blurry...
Hellbilly is offline
The Following User Says Thank You to Hellbilly For this addition to TDG:
Rosco (10-01-2009)
post #8 of 9 (permalink) Old 09-30-2009, 06:22 PM
Does the indicator light on the instrumental panel button illuminate ?
Likely a sensor has faulted. As stated, dirty/salt on sensors can cause the issue.
Specifically I have had issue with the sensors on the outboard taking debris from the road in the winter (salt in particular) off the tire spray. Corrosion worked its way into the sensor itself.
Quick Check.
1. Ignition on (truck not running)
2. Transmission in reverse on level ground - smart to block wheels
3. Walk behind vehicle and listen to each sensor (tick like sonar when operating correctly).
4. Inspect connection on those not "ticking". A shot of contact cleaner and compressed air fixed mine. If they are all not ticking, start working backward to the main connector - near spare tire. Try contact cleaner here as well.
5. Beyond this, the module could be shot.
2008 F450 - Pearl Blue with Tan - 4.30 (Job 3)
Spartan 310hp w/TCM, Airaid Drop In Filter, 5" MBRP w/ 6" Tip, 2" level kit, Firestone Air bags in the rear, Bilstein's all around
2010 Open Range 429bhs 5th
http://good-times.webshots.com/album/565591458baIstp
Black06 is offline
The Following 2 Users Say Thank You to Black06 For this addition to TDG:
Rosco (10-01-2009), smurfz (09-21-2011)
post #9 of 9 (permalink) Old 05-03-2011, 09:50 AM
08smoker08's Avatar
Black06, what module do you speak of and where is it located. My sensors are acting up and all of them are ticking. What gives?
2008 Job 1 F-250 PSD
H&S Black Maxx
S&B intake
5" Flow Pro from DP Back
Michelin LTX-AT2
Tow Pkg
Snow Plow Pkg
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(TheDieselGarage.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
08smoker08 is offline
back up sensors water101 2008-2010 6.4L Power Stroke 8 08-30-2009 09:13 PM
Back up alarm sensors and the Cold Hollywood 2008-2010 Body & Suspension 11 03-20-2009 11:51 PM
Back up sensors. TubingJon 2008-2010 6.4L Power Stroke 1 12-28-2008 03:29 AM
back up warnig sensors? strokedout_07 General Ford Truck and Excursion 4 12-28-2007 09:18 AM
Back up sensors? 04-F350 2003-2007 6.0L Power Stroke 0 09-28-2006 02:45 AM
