Steering Play - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smurfz, this thread has received 28 replies and been viewed 2461 times.
post #1 of 29 (permalink) Old 10-06-2009, 06:20 PM Thread Starter
Super *********
smurfz's Avatar
Steering Play
I was at the suspension shop and they did an alignment. When I left there was HUGE play in the steering and it was like driving a Mack Truck. I went back and they "adjusted" the play and now the dam thing takes two hands to move the wheel. As I seem to have upset the mechanic who worked on my truck is there a quick adjustment that I can make to back off the steering pressure? On my old 76 Colt I could loosen a nut and adjust the rack with a screwdriver and then tighten the nut. Does that adjustment exist on our trucks?
BigTruck, Some Mods Blah Blah (Oh Yeah Spartan Tuned! with the 310, TCM and Fully Powestroked from the Turbo back!)
Canadian Club Member # 13
smurfz is offline
post #2 of 29 (permalink) Old 10-07-2009, 02:12 AM
I like Pretty Girls!
Hollywood's Avatar
Must be something if they can change it... last time I complained about steering play they replaced the ball joint looking unit for the steering "track bar" (I believe thats what it is)
My old Fords used to have that adjustment but I haven't looked on this one
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
post #3 of 29 (permalink) Old 10-07-2009, 03:55 AM Thread Starter
Super *********
smurfz's Avatar
It has a new track bar and the play bad then non existant happend with out it being replaced
smurfz is offline
post #4 of 29 (permalink) Old 10-07-2009, 06:37 PM
ZeroOne's Avatar
Maybe they adjusted the steering box? If by "play" you mean, driving down the road, you can turn the wheel back and forth loosely, over a small arc. If they tightened the box, I think it is adjustment on top of the box (above the pitman arm). There should be a jam nut and the adjuster. Loosen the jam nut, then back off the adjustment nut slightly and tighten the jam nut again. Maybe someone who has actually done this themselves can confirm this. I've only read about it. This procedure tightens the sector shaft (that the pitman is mounted to), making the box have less play between the steering column and sector/pitman.
ZeroOne is offline
post #5 of 29 (permalink) Old 10-07-2009, 06:38 PM Thread Starter
Super *********
smurfz's Avatar
I will try that. Sounds logical
smurfz is offline
post #6 of 29 (permalink) Old 10-07-2009, 06:44 PM
ZeroOne's Avatar
Just remember to make very small adjustments. Think of adjusting forks on a bicycle. Tighten the forks TOO much and they will bind on the bearings when steering the handlebars, but too little, and the forks/handlebars will clunk around.
ZeroOne is offline
post #7 of 29 (permalink) Old 10-07-2009, 06:46 PM Thread Starter
Super *********
smurfz's Avatar
Will do
smurfz is offline
post #8 of 29 (permalink) Old 10-07-2009, 06:53 PM
Auto's are for pansies
Slick Willie's Avatar
Do you have any documents from the alignment shop stating what they did? You may need those later if that weak steering gearbox goes.
Slick Willie is offline
post #9 of 29 (permalink) Old 10-07-2009, 06:57 PM Thread Starter
Super *********
smurfz's Avatar
Paid CASH and got a handshake when I left the first time. Second time I got a glare and virtual "Kick in the butt"
smurfz is offline
post #10 of 29 (permalink) Old 10-07-2009, 08:42 PM
O2ShootTheJ's Avatar
hate people like that. If you make a mistake on someones vehicle it is your obligation to fix it.
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
Play in the steering wheel Superstroker 2003-2007 6.0L Power Stroke 10 12-13-2009 09:54 PM
Steering wheel play drgriff General Ford Truck and Excursion 17 04-18-2009 03:47 PM
play in steering wheel jrdragdad General GM Truck Forum 2 03-31-2008 12:28 AM
Play in Steering, new shaft? blueovalcj General Dodge Discussion 1 08-10-2007 04:36 AM
play in the steering wheel ??? strokedout_07 1994-2003 7.3L Power Stroke 2 08-10-2007 12:40 AM
