Removing rust... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BigPSD, this thread has received 1 replies and been viewed 627 times.
post #1 of 2 (permalink) Old 11-14-2009, 07:44 PM Thread Starter
BigPSD's Avatar
Removing rust...
Don't worry no body rust!
So my front drivers side brake pad blew apart on my way home from a trip. I took it easy the whole way home using the gears to slow the truck down, but the rotor still took a good beating. Went out to do the brake job and there noticed a ton of rust particle build up on the wheel and aluminum on the running board. Most of it will rub off expect for some parts. Anyone have an idea on what I could use to remove it?
BigPSD is offline
post #2 of 2 (permalink) Old 11-15-2009, 01:23 PM
UpstateDieselGuy's Avatar
Clay Bar will probably be the best place to start. It works very well at removing the small pieces of metal that cause the small rust spots gently. Chris
SOLD
UpstateDieselGuy is offline
The Following User Says Thank You to UpstateDieselGuy For this addition to TDG:
BigPSD (11-16-2009)
Rust...? Paste42 5.9L Cummins (2003-2007.5) 1 02-16-2009 02:08 PM
Where's the rust? Rcannon General Ford Truck and Excursion 6 06-28-2007 08:17 PM
Rust on oil pan imported_99powerstroke 1994-2003 7.3L Power Stroke 3 09-07-2006 02:19 AM
Muratic acid for removing rust RacerX The Detailing, Paint & Bodyshop 2 07-15-2006 05:55 AM
Rust BROKER 5.9L Cummins (2003-2007.5) 2 06-13-2005 12:53 AM
