Ladder bar help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Super08Duty, this thread has received 11 replies and been viewed 1574 times.
post #1 of 12 (permalink) Old 11-15-2009, 04:46 AM Thread Starter
Diesel Kid
Super08Duty's Avatar
Ladder bar help
So im building up my own set of Ladder bars. Not traction bars. what i need to know is: What length do they need to be for my 4.5" lift? i have 35's but will be moving up to 37's in a year or so. I heard they dont need to be as long as trac bars but im a bit confused. Pics would be awesome too. the truck is also a supercab so pics of ladder bars or traction bars on a crew cab do me no good.
Colton
2008 F-250 PSD 4X4 XLT
Spartan-MBRP-Elite-AFE-KEM
542hp 1060trq 9/18/10
Super08Duty is offline
post #2 of 12 (permalink) Old 11-16-2009, 05:08 AM Thread Starter
Diesel Kid
bump
Colton
post #3 of 12 (permalink) Old 11-16-2009, 12:28 PM
O2ShootTheJ's Avatar
whats the difference between ladder and traction bars?
Singles Club #222
December 2008 TOTM
Riding High Club #2
2008 Truck of the Year
Ridin' Dirty Club #2
Big Thanks to:
O2ShootTheJ is offline
post #4 of 12 (permalink) Old 11-16-2009, 02:36 PM
BLING BLING
Blk350on20s's Avatar
Send a message via AIM to Blk350on20s
Ladder bars are full floating and Y'd at the axle and traction bars are solid mount and 1 bar. Im assuming thats what hes talking about. There is really no length requirement. The longer the better but use the right equipment and it shouldnt matter. Basically mock up a set that goes past your front leaf mount and wont hit it. I wanted to use a set of rear leaf spring hangars and shackle from a superduty to make the front ladder bar mount. I think that would work pretty good. Let us know how it goes. I would like to get a set here in the near future but would rather build them. Just dont have the equipment to do so. Ryan
08 F350 4x4 CCSB 6.4, 6" on 37s and 22s, Spartan DD w/ 310/KEM 345, Elite HPFP, Ported rails, EGR delete w/ wastegate, studs, CFM +, Rudys IC pipe, BD BOV, FASS 150 w/ custom fuel system, S&B intake, Rudys downpipe and DOC/DPF delete, CCV mod, Zex nitrous, Suncoast Trans, 1 piece drive shaft, Recon and tint everywhere. Under Construction
Blk350on20s is offline
The Following User Says Thank You to Blk350on20s For this addition to TDG:
Super08Duty (11-16-2009)
post #5 of 12 (permalink) Old 11-16-2009, 02:57 PM
Auto's are for pansies
Slick Willie's Avatar
Are you going to weld the front mounts to the frame or try to bolt it to the frame? Look up under there and see how much room you have, if there are already some holes you can take advantage of, etc.
Tire size won't affect the ladder bars. Suspension lift changes will, but not tire size.
Slick Willie is offline
The Following User Says Thank You to Slick Willie For this addition to TDG:
post #6 of 12 (permalink) Old 11-16-2009, 05:06 PM Thread Starter
Diesel Kid
not sure yet, if there are holes under there already then i will bolt em up. might be welding them to frame though, and weld them to the axle if im correct? would 6ft bars be good? hardest part for me is making the bracket that mounts to the axle.
Colton
post #7 of 12 (permalink) Old 11-19-2009, 02:49 AM
I Wanna Go Fast!
brentos's Avatar
i make all my tbars around 6ft. to make a decent looking ladder bar you will need a plazma cutter or lazer cut pieces for the axle brackets
brentos is offline
post #8 of 12 (permalink) Old 11-19-2009, 03:59 AM Thread Starter
Diesel Kid
I have a plasma cutter which i will be using. just confused to what the bracket should look like.
Colton
post #9 of 12 (permalink) Old 11-19-2009, 08:57 PM
http://lmgtfy.com/?q=ladder+bar+bracket+pictures
post #10 of 12 (permalink) Old 11-23-2009, 05:02 AM Thread Starter
Diesel Kid
haha Ive googled for hours. guess i'll just have to make some cardboard cut outs first to see how they'll look.
Colton
Has anybody put a set of ladder bars on yet? Brutus the Grey 6.7L Cummins (2007.5-2011) 0 11-05-2007 06:26 PM
ladder or traction bar tjl Supporting Vendors Forum 2 07-04-2007 05:52 PM
Ladder Bars Extended Power General Ford Truck and Excursion 14 07-01-2007 09:49 PM
ladder bars pwrstroke99 Sled Pulling 8 05-04-2007 02:30 AM
ladder bars ntnbtwk 2003-2007 6.0L Power Stroke 17 08-26-2005 02:57 AM
