Heated seats stopped working - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by smurfz, this thread has received 15 replies and been viewed 7766 times.
post #1 of 16 (permalink) Old 12-07-2009, 07:00 PM Thread Starter
Super *********
smurfz's Avatar
HELP. On of my heated seats has stopped working. Drivers side light comes on the dash but no heat. There is a rats nest of wired under there with the power seat module. Any idea which oine is the Seat Heat so I can diag back
BigTruck, Some Mods Blah Blah (Oh Yeah Spartan Tuned! with the 310, TCM and Fully Powestroked from the Turbo back!)
Canadian Club Member # 13
smurfz is offline
post #2 of 16 (permalink) Old 12-07-2009, 07:12 PM
I like Pretty Girls!
Hollywood's Avatar
I looked at the "heated seat with Upfitter switches mod" and it said "yellow/blue" for the drivers side.... but I havent' done this mod.... Yet
Do you hear the "clicking" noise when the seat is turned on? and I have to assume you checked the fuses/relays?
2008 F-350 Lariat
6" Lift Riding on 37x13.5 Toyos
Canadian Club Member #12
Hollywood is offline
post #3 of 16 (permalink) Old 12-07-2009, 07:31 PM Thread Starter
Super *********
smurfz's Avatar
There are about 15 Yellow Blue Wires there. Yes the Relay "clicks" and the Passenger works fine
smurfz is offline
post #4 of 16 (permalink) Old 12-07-2009, 09:44 PM
Hollywood's Avatar
OK look from the front of the seat and you will see the realy (I just looked to confirm this) and you should be able to test for power at the relay....
2008 F-350 Lariat
The Following User Says Thank You to Hollywood For this addition to TDG:
smurfz (12-08-2009)
post #5 of 16 (permalink) Old 12-08-2009, 07:09 AM
4play's Avatar
as said above look at the heated seat relay, it is basically at the front of the seat on the bottom, should have 4 wires going to it ( YE-RD, WH-BU, YE-BU and GN(maybe-unsure about green) YE=yellow, RD=red, WH=white, BU=blue.
The YE-RD is the power into the relay for the elements (hot all the time from fuse 18-SJB)
The GN? is the power wire for the switching side of realy (hot in run from fuse 42-SJB)
The WH/BU is the ground side of the relay (on/off switch grounds wire for "ON")
The YE/BU is the power out to the heater elements.
The YE/BU wire powers both elements in series going through the seat cushion first, then through the back. It changes color to GY/BK (grey/black) leaving the seat cushion element to the seat back element, then changes to BK/VT (black/violet) leaving the seat back element to ground.
A simple test lamp can check the heater element circuits, I would bet you have an open circuit in the Seat Element. check for power before and after the seat elements to see if they're open.
4play is offline
smurfz (12-08-2009)
post #6 of 16 (permalink) Old 12-08-2009, 11:53 AM Thread Starter
Super *********
smurfz's Avatar
Ok being at work and having no tools I found the relays and I swapped out the working Passenger one with the non working driver side. Still the driver side did not work so I presume the element is broken. I will have to confirm this with a test light. If the element is broken is this something that can be repaired or simply just replaced. If it is replaced then it is easy to do. If so I will swap out the passenger with the driver. Thanks for info guys
smurfz is offline
post #7 of 16 (permalink) Old 12-08-2009, 02:20 PM
4play's Avatar
the elements are known to break or burn in two. see it more with the cushions than backs. If element(s) are bad you have to remove the seat from truck, dis-assemble seat (seat track, trim, seat back etc..), remove cushion cover (clips and hog rings) the element is sandwiched between the leather cover and foam pad.
4play is offline
smurfz (12-08-2009)
post #8 of 16 (permalink) Old 12-08-2009, 02:23 PM Thread Starter
Super *********
smurfz's Avatar
Crap. Guess I am gona have a cold butt
smurfz is offline
post #9 of 16 (permalink) Old 12-08-2009, 03:15 PM
Hollywood's Avatar
, figures it breaks when it gets super cold out!! but If you have a sensitive but go to Crappy Tire and buy one of those cheap heated seat covers bucks until you get your fixed
2008 F-350 Lariat
smurfz (12-08-2009)
post #10 of 16 (permalink) Old 12-08-2009, 04:42 PM
Hollywood's Avatar
So 4-play do you know about the Mod where you run a upfitter switch to the relay? My sheets say to run a switch to the Yellow green, if I do that wont that by pass the switch and be "hot" all the time the switch is on?
I am fine with that I jsut dont want to mess anything up and I am going to do this today or tomorrow.... getting cold here
2008 F-350 Lariat
SYNC stopped working Rene G 2008-2010 6.4L Power Stroke 3 05-19-2009 03:00 AM
heated seats jdreda Duramax 2001-2004 (LB7) 4 01-28-2009 02:52 AM
Heated seats??? MRBOHN23 General Ford Truck and Excursion 3 12-12-2007 08:24 AM
a/c stopped working brietwyk 1994-2003 7.3L Power Stroke 12 10-10-2007 01:12 PM
A/c stopped working. Then starts again??? jeffro22 2003-2007 6.0L Power Stroke 16 07-19-2006 09:56 PM
