2008 f250 ball-joint steering box out at 40k no warranty help!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jbaker09, this thread has received 8 replies and been viewed 4704 times.
post #1 of 9 (permalink) Old 01-05-2010, 06:25 PM Thread Starter
I have a 2008 f-250 40,900 miles on it. been have bump steer issues for about 4months took to tire store figured had a bad tire. they check the truck out rebalanced tires.. still no fix this has been going on for 4 months back and forth Finally at 40k on my last lube/oil/filter change I ask the suspension tech to check the front end. I gave him a ride in the truck to duplicate the problem, which it did at 70mph on some bumps. Severe bump steer, tech took this in check it. now it needs a new steering box, lower ball joints and a tie rod end.. The tech claimed the leveling kit, and the 325/60/20 tires caused the problem. and that the warranty was out at 36k i had to foot the whole bill of 2900.00.. i complained that this has been going on for sometime and it should be covered.. they came back and said they have never heard of ball joints or steering box issues from these trucks and it was due to the tire/ lift kit.. which it was a leveling kit. After some heated discussion they came back and said if i paid a third they would pay a third and ford a third.. which is around 900.00 . Not to mention I have to purchase a new set of tires due to the aligment has ruined them.. Is there a number I can call to talk to ford or what should I do... HELP.. ill be out 3k and the damn truck has 40k 4000 miles after the warranty expired...
jbaker09 is offline
post #2 of 9 (permalink) Old 01-05-2010, 06:47 PM
I Eat Rice
forcefed6.4ford's Avatar
THey would have to prove that it was the leveling kit that caused the ball joints and steering box to fail. I had to replace my steering box about 25,000km ago and just did the tie rod ends last week. Ive got 142,000km on mine.
If the truck has been in and out for over 4mnths. I think they should cover it because the truck was under warrenty then. The steering boxes on these trucks seem to be a bit of an issue. I've heard of several needing to be swapped out after 10-20,000miles.
Who installed the leveling kit? Was there a wheel alinement done after?
Canadian Club Member #10.
Ridin High Club Member #24
Singles Club Member #469
forcefed6.4ford is offline
post #3 of 9 (permalink) Old 01-05-2010, 07:04 PM Thread Starter
I installed the level kit and yes actually had the truck aligned twice due to the irregular tire wear.. At the dealership I would have them check it during my routine service. They always said it drove fine and couldnt find any issues. When I brought this up to them at the time of the price and problems finally found then they said sorry we dont remember this and dont have any notes on this problem in your record. the tech himself said there was a problem with it, thats when i said lets go for a drive and he saw it for himself.
jbaker09 is offline
post #4 of 9 (permalink) Old 01-06-2010, 06:40 PM
Skyd Ram's Avatar
My question would be;
$3k for balljoint,a tie rod end,and steering box? WTF?
You could get that done with high end aftermarket parts for probably half of that?
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #5 of 9 (permalink) Old 01-06-2010, 07:51 PM
bushpilot's Avatar
250 bucks in ball joint parts...but dealers charge anywhere from 900-1200 just
to do the ball joint job <insane> !
Don R.
Truck Audio,
bushpilot is offline
post #6 of 9 (permalink) Old 01-07-2010, 05:28 PM Thread Starter
i agree.. Should I call ford and speak to someone there. maybe get this crap corrected without anything out of my pocket.. does anyone have a number and can i expect this again in 40k...
jbaker09 is offline
post #7 of 9 (permalink) Old 01-08-2010, 03:24 AM
Mafia member #6
Rutcutter's Avatar
Wouldn't hurt,call customer service..
2011 SD F350 6.7L
White Platinum Tri Coat
Lariat Ultimate Pkg.
GenII Warn winch mount
Autospring 2" Leveling Kit
35/12.50/20 Toyo M/T's
Dually rear center light
6K HID Headlights/fogs
2008 SD CC 6.4L 4x4 (SOLD)
2010 Camo Outlander 800XT DPS
Rollin' on 30" zilla's
Rutcutter is offline
post #8 of 9 (permalink) Old 01-10-2010, 03:32 PM
These steering boxes can be tightened up quite a bit! Might buy some more miles out of it unless it's already maxed out or completely wrecked!
smoxy is offline
post #9 of 9 (permalink) Old 01-10-2010, 07:49 PM
FukeneH
dirty mech's Avatar
for leveling kit why would you do a alinement?
dirty mech is offline
Ball Joint help Snowaholic 5.9L Cummins (2003-2007.5) 0 03-13-2009 07:11 PM
Ball Joint Help.... 99fordtruckguy 1994-2003 7.3L Power Stroke 7 02-17-2008 05:25 PM
ball joint? bisket General Ford Truck and Excursion 6 01-30-2008 12:01 AM
Steering wanders after ball joint replacement Deezle_Dog 2003-2007 6.0L Power Stroke 20 10-25-2007 09:08 PM
Ball joint ????? Diesel Dog General Ford Truck and Excursion 9 06-27-2006 05:25 AM
