F250 Making into F350 !!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by taz1, this thread has received 9 replies and been viewed 5127 times.
post #1 of 10 (permalink) Old 01-11-2010, 04:57 AM Thread Starter
Hi i have an f250 fx4 and i want to put in the f350 rear blocks because they are 2 inches higher. And going to level the front after. My truck sites level know. So i wont need more than a 2 inch level kit after. So what do i need to do for shock extentions and any other stuff i need so it is right. like bearing carrier spacer or whatever. i was thinking newton lifts!! thanks
taz1 is offline
post #2 of 10 (permalink) Old 01-11-2010, 08:52 PM
I did the same thing to my 250 as your talking about. I only put longer shocks in the front, I was told the rears in both the 250's and 350's were the same.
Sandbox is offline
post #3 of 10 (permalink) Old 01-11-2010, 09:30 PM
Auto's are for pansies
Slick Willie's Avatar
If you put stock F 350 rear blocks in the rear, you'll need 2.5" lift for the front. I run 2.5" AutoSpring front pucks, they're $79 shipped to your door, it took me 2 hours to install them in my driveway with 2 bottle jacks and hand tools. No shock extensions, no trac bar relocation brackets, no longer brake lines, nothing. BUT since you're lifting the rear, you'll need a carrier bearing spacer for the rear driveshaft. It's pretty easy to install. Ask rod.10853 about it, he did it on his F250.
Slick Willie is offline
post #4 of 10 (permalink) Old 01-12-2010, 01:42 AM
R.I.P. DAD
SEABEE08FX4's Avatar
You will still have the f250 springs so really its still a f250. Do the springs to.
R.I.P. TMCS (SS) Brooks R Newell, I will forever miss you.
OneBigAssMistakeAmerica
2008 F-250 FX4
NMCB-28, KICKIN BUTT SINCE 1942
American club member #40
FOSP Club # 1
My sense of humor is an acquired taste, if you dont like it....... ACQUIRE some taste.
SEABEE08FX4 is offline
post #5 of 10 (permalink) Old 01-12-2010, 04:27 PM
rod.10853's Avatar
The 2.5" front coil spacer that Will used will work perfectly ... and has a great price.
I lifted mine 2" in the rear, and added a 1/2" carrier bearing spacer. The spacer is very easy to install. I never tried it without the spacer. All is well with the spacer in. But, I've thought about removing it to see what happens.
I was under a stock 08 F350 a while back and I don't think there was a carrier bearing spacer on it. The 08 F250 has a 1.9" block. And, I think the 08 F350 has a 3.5" block. Both trucks I'm referring to are long bed trucks.
Rodney
08 F250 CC LWB 4x4 PSD, 6 SPD-Manual, 3.73 LS
2.5" Leveling Kit / 2" Superlift Add-a-Leaf
18" MT Classic II Wheels / 35" Toyo MT Tires
Go Industries Rancher Grille Guard
SnugTop Truck Cap/Shell
Xtreme Liner
rod.10853 is offline
post #6 of 10 (permalink) Old 01-14-2010, 01:26 AM
git-r-done
TSGS69400's Avatar
My 350 dosent have a spacer. The rear blocks are roghly 3 5/8" thick but they are wedged for pinion angle. i had the 250 blocks in mine for a while but they were too low. I am going to go with a 2 1/2" to 3" block.
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #7 of 10 (permalink) Old 01-17-2010, 06:47 PM
supr87gt's Avatar
Anyone got any before/after pics?
2008 Lariat, CC, SB, 3.73, stock 20's
-High idle mod
1987 Mustang GT
-331 CI A4 block
-95# injectors
-90mm TB
-80mm turbo
-Powerglide
-3.27 gear
-28x10.5 ET Drag
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
supr87gt is offline
post #8 of 10 (permalink) Old 01-19-2010, 02:25 PM
where do you get eth 350 blocks? will U bolts work from the 250 for the 350 block
whata bout the carrier bearing spacer?
wanting to throw on Nittos 37x13.5x20s on my stock wheels
2008 F250 King Ranch 4x4 Black, 5% Limo tint all around, Spartan 310, Dfuser 4" SS DPF/DOC delete, Husky Liners crappy goodyears, sweet mesh side vents made by myself!
ruger311 is offline
post #9 of 10 (permalink) Old 01-25-2010, 03:47 PM
Gonna rub the control arms with 37's on stock rims - stock rims don't pooch out enough.
Here is my 2.5" front install (35's on stock 18's at that time):
post #10 of 10 (permalink) Old 01-25-2010, 03:55 PM
not too bad
ruger311 is offline
Anyone looking to buy a '06 F250? wife making me sell mine Jeremiah Vehicles For Sale 12 01-09-2010 09:39 PM
Making 92 F350 auto into a manual tranny OzarkSaints General Ford Truck and Excursion 2 10-27-2009 03:24 AM
F250 vs F350 which to get. azdrt 2008-2010 6.4L Power Stroke 43 07-01-2007 09:33 AM
making a f250 drw liftedwj357 1994-2003 7.3L Power Stroke 2 06-06-2007 04:46 PM
73-79 F100 F250 F350 !! Muddin Whats Been Sold 0 02-08-2007 02:58 PM
