08 door removal and speaker adapter???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Crown Vic Guy, this thread has received 7 replies and been viewed 1195 times.
post #1 of 8 (permalink) Old 02-25-2010, 06:20 AM Thread Starter
Does anyone know where to find the speaker wire adapters that fit an 08 FX4 CrewCab with a baseline stereo (am/fm/cd) system? Also, does anyone have a written procedure for removing the doors to replace these speakers?
I really don't wanna cut into the wiring if I don't have to, but then again it wouldn't be the first time.
Kyle
Crown Vic Guy is offline
post #2 of 8 (permalink) Old 02-25-2010, 02:24 PM
not sure on the wires and speakers but the door removal is easy. Just underneath the inside door handle/arm rest there is a little rectangle removeable plastic piece. pull that out and there are 2 screws behind it. take the screws out and then the door pannel will lift up and come off. actaully if i remember right there were a bunch of wires on the inside that you could see...not sure if any of them are what your lookin for or not.
CornellCowboy is offline
The Following User Says Thank You to CornellCowboy For this addition to TDG:
Crown Vic Guy (02-26-2010)
post #3 of 8 (permalink) Old 02-26-2010, 04:14 AM Thread Starter
door removal seems easy enough, now if finding the speaker wire connectors was just as easy........
post #4 of 8 (permalink) Old 02-26-2010, 06:42 PM
dwoz2012's Avatar
Look at crutchfield for the adapter from oem to aftermarket speakers. If your oem wires are cut I would go to a junk yard and get the oem connectors and slice them in. Hope this gives you a way of doing your mod. At crutchfield they can give you all the tech support to do your job
2008 F250 6.4, Recon smoked led clearance, side view, and thrid brake light. Skyjacker 4 inch lift with new front and rear springs, skyjacker steering stab. 18 inch badland wheels, cooper 35 inch STT's. linex spryed bed, 3D chromed superduty tail gate letters, Bflip bed cover, Windows Tinted out, remote start, and more to come
dwoz2012 is offline
The Following User Says Thank You to dwoz2012 For this addition to TDG:
Crown Vic Guy (02-27-2010)
post #5 of 8 (permalink) Old 02-27-2010, 03:16 AM Thread Starter
I honestly forgot all about that company. I order from them many moons ago, but have since found much cheaper venues. I think I will call them in the morning to see what I can find out. Thanks for the suggestion.
post #6 of 8 (permalink) Old 03-02-2010, 03:38 AM
Sawed Off's Avatar
I've cheated in the past. You can take a spade or fork end terminal and crimp it onto a wire to make a harness. It just depends on what your harness looks like going to the oem speaker. hope this helps.
2010 6.4 CC
The Diesel Garage
Can You Keep Up
MODS
recon lights
20" predator8 wheels
Toyo AT's
Rip 06 6.0 You were a great truck and will be missed
Sawed Off is offline
post #7 of 8 (permalink) Old 03-04-2010, 04:55 PM
I bought speaker adapter wires from Crutchfield when I upgraded my speakers.
2008 F-350 6.4 Power Stroke 4X4
CC LWB SRW Auto 3.73's
BigIslandBoy is offline
post #8 of 8 (permalink) Old 03-09-2010, 07:03 AM Thread Starter
yea, made the jump and ordered them from crutchfield as well. I also ordered the 6x8/5x7 Infinity Kappa door speakers as well. Found 2 pair for 140 plus shipping on amazon! Thanks for all the input guys!
Door panel removal? Okieboy General Ford Truck and Excursion 1 02-20-2008 05:12 AM
Door/seatbelt dinger and door seal mod...awesome... John_DeereGreen 1994-2003 7.3L Power Stroke 18 12-24-2007 09:15 PM
Door panel removal POWER STROKE 99 1994-2003 7.3L Power Stroke 13 11-12-2007 04:18 AM
INterior Door Pannel Removal 199eightcummins General Dodge Discussion 5 07-22-2007 01:41 AM
Inner door panel removal imported_Hanging_Heels 2008-2010 6.4L Power Stroke 6 05-17-2007 01:17 AM
