6.0 Alphabet soup - making sense of all the Jargon - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Weld engineer, this thread has received 8 replies and been viewed 3641 times.
post #1 of 9 (permalink) Old 02-16-2013, 07:03 PM Thread Starter
Weld engineer's Avatar
Neeltburn
Hopefully we can make this a sticky after some feedback and review
https://www.thedieselgarage.com/uploads/6_0bible.htm
AR – Archoil oil additives (manufacturer)
ARP – Manfacturer of studs for replacing stock head bolts
AP – Accelerator pedal
Baro – barometric pressure
BST – Boost or pressure created by the turbo at the intake of the engine
CAT – Catalytic converter
CKP – crankshaft position
CMP – Camshaft position
ECT – Engine coolant temperature
EGRVP – Exhaust gas recirculation valve position
EOP – Engine oil pressure (it is a switch on the 6.0 not a real gauge)
EP – Exhaust pressure
EBP –Exhaust back pressure
ELC – Extended life coolant (some members prefer it over Ford Gold coolant normally associated with Caterpillar)
ECM – Electronic Control module
EGR – Exhaust gas recirculator (valve) (cooler)
ESOF – Electronic shift on the fly (vacuum actuated lockouts and transfer case actuator)
FICM – Fuel Injection Control Module
GPCM – Glow plug control module
HEUI – Hydraulically actuated Electronically controlled Unit Injector (Caterpillar design licensed to International)
HG- Head gaskets
HFCM – horizontal fuel conditioning module (located on the frame rail and has 1st stage filter in it and water separator
HPOP – High pressure oil pump (supplies the injectors with high pressure oil for injecting fuel into the cylinders)
IAT1 – intake air temp 1
IAT2 – intake air temp 2
ICP – Injection control pressure (a sensor near turbo on 2003 and early 2004, on the passenger side valve cover of all later models)
IPR – Injection Pressure regulator (used to adjust commanded oil pressure to the injection system
MAF – Mass air flow
MAP – Manifold absolute pressure
MC – Motorcraft (Ford OEM)
OEM – Original equipment manufacturer
PCM – Progammable control module
REV-X – a brand of oil additive (manufacturer)
SCT – a brand of tuner that programs the PCM with engine and transmission file to create a particular performance level
SG2 – Scangauge 2 (or II it is a low cost gauge that can display most of the 6.0 sensors and diagnostic codes works off of the OBD-II port while engine is running)
TFT – Transmission fluid temperator
TTY – torque to yield (stock head bolts are torqued until they yield unlike ARP studs)
VGT – Variable Geometry Turbo – (Garrett Design)
VGTCV – Variable Geometry control valve
VVT – Variable Vane Turbo – (see VGT)
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
The Following 5 Users Say Thank You to Weld engineer For this addition to TDG:
Bderick67 (02-22-2013), bear1 (06-09-2013), harry6.0 (02-17-2013), mabynack (10-28-2014), MT Pockets (02-17-2013)
post #2 of 9 (permalink) Old 02-17-2013, 01:44 AM
ADMIN/MAFIA
neeltburn's Avatar
Done!
Sent from my IPhone 4s An AT&T not so 4G phone via Tapatalk.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
Weld engineer (02-17-2013)
post #3 of 9 (permalink) Old 02-17-2013, 03:50 PM
harry6.0's Avatar
Awesome job of making a cheat sheet list of acronyms Weld! Well done!
And thanks Neel for making this a sticky!
Harry
harry6.0 is offline
post #4 of 9 (permalink) Old 02-22-2013, 07:31 PM
diesel newbie
Bderick67's Avatar
OMG!!! This is going to be so helpful. Can't believe how much time I've been wasting research acronyms.
Bderick67 is offline
The Following User Says Thank You to Bderick67 For this addition to TDG:
Weld engineer (02-22-2013)
post #5 of 9 (permalink) Old 03-28-2013, 01:44 AM
Man i'll remember about 1/2 of these! Thanks, and thank God for bookmarks!
Bubba91166 is offline
The Following User Says Thank You to Bubba91166 For this addition to TDG:
Weld engineer (03-28-2013)
post #6 of 9 (permalink) Old 04-14-2013, 02:56 PM Thread Starter
Addition to list
STC -
Snap To Connect - is a fitting in the HPOP system that is prone to failure on later models of the 6.0 high pressure oil system. It is found near the pump. Upgraded versions are available to remedy the issue
The Following User Says Thank You to Weld engineer For this addition to TDG:
broncobob (04-14-2013)
post #7 of 9 (permalink) Old 10-06-2013, 03:29 PM
What is EOT ?
bear1 is offline
The Following User Says Thank You to bear1 For this addition to TDG:
Weld engineer (10-06-2013)
post #8 of 9 (permalink) Old 10-06-2013, 03:35 PM Thread Starter
EOT = Engine Oil Temperature
post #9 of 9 (permalink) Old 10-06-2013, 04:51 PM
Aimless Wanderer
Try contracting with the government for an exercise with acronyms......
Backslap is offline
soup bowl mod? fordfreak 7.3L and 6.9 IDI (Pre 1994) 10 02-25-2008 05:21 PM
Does this make sense??? jennamax 2003-2007 6.0L Power Stroke 16 05-03-2007 02:13 AM
Common Sense Gone??? bigdraft The Parking Lot 3 08-12-2005 07:58 PM
This Makes No Sense ............. BROKER The Parking Lot 2 06-03-2005 04:53 AM
