Auto to 6spd? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strawboss, this thread has received 20 replies and been viewed 2560 times.
post #1 of 21 (permalink) Old 06-22-2010, 01:55 AM Thread Starter
strawboss's Avatar
Auto to 6spd?
Working out a deal to swap my 5r110 cummins adapter parts to help a friend swap out his 6.0 to a real motor! My question is will a late model 6spd bolt up to the older 5.9?
And I'm going to swap the column shift for a floor shifter. Any Ideas?
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
post #2 of 21 (permalink) Old 06-22-2010, 05:18 AM
SSpeeDEMONSS's Avatar
a g56? it needs a different motor plate. then obviously the other clutch parts.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
strawboss (06-22-2010)
post #3 of 21 (permalink) Old 06-22-2010, 10:32 AM Thread Starter
strawboss's Avatar
school me!!! G56? I've got an 07 dodge and would like the same tranny but different clutch(suggestions?) Sspeed, what do you define as a motorplate?
post #4 of 21 (permalink) Old 06-22-2010, 08:10 PM
Basically the adapter plate on the back of the motor that the bellhousing bolts too. Maybe its not called the motor plate. I posted thay kinda late last night and that's what popped into my head. A g56 should be what's in the dodges after the nv5600. I think they started in 03 or 04, don't quote me cuz I don't know a whole lot about the 3rd gen stuff.
What kind of clutch are you wanting to get?
post #5 of 21 (permalink) Old 06-23-2010, 01:52 AM Thread Starter
strawboss's Avatar
Clutch.....Well haven't given it much thought, south bend or something like it, I want a good one because i hate doing something twice.
I can't make up my mind if i want the dodge transfer case or keep the ford.
post #6 of 21 (permalink) Old 06-23-2010, 03:22 AM
TDG Mafia Goon
BombDocDiesel's Avatar
You will probably have to keep the Ford transfer case. Your tone ring/reluctor for your speedo should be in there.
I have an extra 5.9 plate. I just pulled my NV4500 out to put the Allison in. If you are planning to run a Ford ZF-6 you will need to buy an aftermarket plate from one of the conversion guys.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #7 of 21 (permalink) Old 06-23-2010, 08:22 AM Thread Starter
strawboss's Avatar
Are you willing to sell the extra plate?
i also need a clutch pedal from a super duty. Wanted!!!!
post #8 of 21 (permalink) Old 06-23-2010, 09:20 PM
look for a clutch pedal out of another superduty. i hear they bolt right up. thats what i plan to do.
i would recommend a dual disc 3200 or 3600 depending on what you plan to do.
if you can get a 6spd from a super duty you keep your stock t-case. my plan is to keep mine and get a dodge input to bolt my nv4500 to it.
post #9 of 21 (permalink) Old 06-24-2010, 10:56 AM Thread Starter
strawboss's Avatar
So, you are keeping the ford t-case and swapping the input shaft to fit the NV4500? iS that a 6spd? I was thinking of the g56....All i want is a better shifting tranny something i can tow with.
post #10 of 21 (permalink) Old 06-24-2010, 05:56 PM
no, i have to swap a dodge 271 input onto my 273 as the spline count is different from dodge to ford.
the NV4500 is a 5spd.
the G56 is a good tranny. if you can find on from a ford it will bolt right up to your t-case then just change out the motor plate. or whatever its called. tranny plate maybe. do the fords even have a g56 or is that a dodge tranny? i dont see an adapter plate for cummins to g56 from destroked. i say give them a call and see what they say. maybe one of the vendors on here that does swaps. GOS would be a good one to call.
looking to buy a 00 7.3/6spd FordRacing200 1994-2003 7.3L Power Stroke 9 05-30-2010 05:28 AM
4spd auto OBS vs SD dually 6spd just visiting 1994-2003 7.3L Power Stroke 4 02-11-2010 02:53 PM
6spd kc04 5.9L Cummins 12 Valve (1994-1998.5) 17 04-17-2009 11:07 PM
6spd VS. Auto StrokerDude 1994-2003 7.3L Power Stroke 7 10-24-2007 03:45 AM
01 ctd qc 4x4 ho 6spd FireMarshal3311 Whats Been Sold 1 08-03-2007 10:55 PM
