cummins mated to the 5R110 torqshift - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokin6L, this thread has received 8 replies and been viewed 13088 times.
post #1 of 9 (permalink) Old 08-28-2010, 12:52 AM Thread Starter
strokin6L's Avatar
I see that destroked makes an adapter plate to mate a cummins to the 5R110 torqshift and was wondering if anyone has done this. I know....why would anyone still use the torqshift when doing a cummins swap and just use the dodge tranny. But i figured if someone already had the 5R110 already built up...they could save some money by keeping it instead of putting the dodge tranny in it and beefing that one up. Just really curious is all incase something were to ever happen to my engine cause i already spent the money to have my tranny built.
strokin6L is offline
post #2 of 9 (permalink) Old 08-28-2010, 01:03 AM
Trip's Avatar
personally I would rather run the 5R110 rather than a dodge trans is there anything wrong with the 5R110... if it weren't for the Cali smog I would be building a nice cummins to mate up with my 5r110
WALNUT (anti-ACORN) member#23
Trip is offline
post #3 of 9 (permalink) Old 08-30-2010, 08:50 PM
Steel's Avatar
This is a touchy subject because some guys swear by their 5R110's, myself being one of them who had already dumped buckets of money into mine to beef it up. However, we have tried to run 5R110s behind Cummins, and it just plain doesn't work, not even behind a stock CR, tried it. The problem is that the 5R valve body is full of all electronic solenoids, vs a 4R100, or dodge tranny that is run by valves instead. Aftermarket controllers, such as the PCS standalone can't command the solenoids fast enough to make the trans shift right. It seems that they are always slamming gears and slipping or hunting for gears. We don't waste our time with 5R110's anymore, been there done that and learned from it. In the end, after you have ripped all of your hair out and considered lighting your truck on fire more than a few times, you will end up ripping the 5R out and going another route anyways.
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
The Following User Says Thank You to Steel For this addition to TDG:
strokin6L (08-31-2010)
post #4 of 9 (permalink) Old 08-30-2010, 11:04 PM
dzljon's Avatar
I have a 2004 48re for sale, if anyone with a 5r wants to do the swap, I personally am using the 4r100, when i get home form Iraq I will deffinatly be doing some business with GOS.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
The Following User Says Thank You to dzljon For this addition to TDG:
Steel (08-31-2010)
post #5 of 9 (permalink) Old 08-31-2010, 12:04 AM
sometimes I wish there were more electronics in the 48re so I could rig up a paddle shifter setup.
04.5 Qcab shorty SRT hood, H2 rims, evil twin cp3's, flux 3.5's, ats 2 piece, S480 under HTT 64 71 13 ss, HTT intercooler, snow stage II, arp's, GOERENDified 48RE billet in and out ! 5 " straight pipe !, Alpine HU Kenwoods all 4 doors, JL subs, JL 500/1 amp, Line-O-Fire, BD steering brace, 6" SS tip, Smarty S-06 TNT R/
mikmaze is offline
post #6 of 9 (permalink) Old 08-31-2010, 09:21 AM
Trip's Avatar
Ok had no idea.... I am glad I stayed tuned in to this thread, I love it when I gain knowledge
Trip is offline
post #7 of 9 (permalink) Old 08-31-2010, 02:32 PM
Steel's Avatar
If you go with a PCS Standalone controller on the 48RE you can set up a paddle-shifter!
See here- PCS Paddleshifter
800-620-4467
Steel is offline
post #8 of 9 (permalink) Old 09-04-2010, 02:48 PM
looks interesting till you get to the part of not used on airbag equipped vehicles........ but hey, ya never know.
mikmaze is offline
post #9 of 9 (permalink) Old 09-07-2010, 09:47 PM
Steel's Avatar
Ah... who needs airbags???
800-620-4467
Steel is offline
TORQSHIFT 6 DOWN ! ! ! !!!! ! Jeremiah 2011+ 6.7L Power Stroke Diesel 40 11-19-2010 03:22 PM
6.4L's TorqShift vs 6.7L's TorqShift Jeremiah 2011+ 6.7L Power Stroke Diesel 5 03-13-2010 01:16 PM
6.0l 5r110 Torque Converter and 6.4l 5r110 suncoast converter Blk350on20s Whats Been Sold 5 02-12-2009 10:12 PM
John Wood 5R110 Torqshift FS IGotIt Whats Been Sold 8 10-07-2007 10:17 PM
5.9 COmmon Rail Cummins to a 5R110 MattBMiller Diesel Conversion 4 06-12-2007 12:42 AM
