1989 F-550 2x4 cummins conversion - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rebel Cummins, this thread has received 28 replies and been viewed 6468 times.
post #1 of 29 (permalink) Old 11-17-2010, 04:18 PM Thread Starter
DIXIENORMOUS 4X4
Rebel Cummins's Avatar
Talking 1989 F-550 2x4 cummins conversion
Out with the 460 in with a 1992 cummins.
Bought a diesel ZF-5-speed with a trans parking break drum.
If you stay tuned i'll be dooing in depth coverage so you can doit your self.
Parts bought for conversion:
500 hp Clutch
Destroked adapter plate
Ford Cummins Engine mounts
twin electic fans
After market voltage regulater.
FSG Transport LLC
Owner-Operator Aug 2010 to present
West Alexandria, Ohio
I'm The Owner of FSG Transport and a driver.
Rebel Cummins is offline
post #2 of 29 (permalink) Old 11-17-2010, 04:30 PM
Gone Fishin...
merlin5577's Avatar
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 29 (permalink) Old 11-17-2010, 09:53 PM
Pardue the Traveler
New 0mega's Avatar
Singles Club member #250
New 0mega is offline
post #4 of 29 (permalink) Old 11-20-2010, 12:45 AM
SSpeeDEMONSS's Avatar
looks like a fun project. lets see the overall picture of the truck.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #5 of 29 (permalink) Old 11-20-2010, 03:11 PM
Fred we need better pic's.
Use photobucket.
What happened to the 350???
Philip is offline
post #6 of 29 (permalink) Old 11-22-2010, 04:35 PM Thread Starter
DIXIENORMOUS 4X4
FSG Transport LLC
post #7 of 29 (permalink) Old 11-24-2010, 09:04 PM Thread Starter
DIXIENORMOUS 4X4
not visible under the steel line but, there is a predriled hole, Line the right side engine mount up behind this hole , should be setting 1/4 of an inch behind the hole.
this hole is visible, line the left engine mount up in front of this hole, should be no less than 1 inch from your newly drilled hole.
(Notice) The transmission mount is in the factory set possition. Most of the people i have talked to told me that the engine and trans should be mooved back no less than 2.50 inchess. Destroked and fordcummins told me this has to be done for clreance on the clutch fan, and you need to trim the fire wall lip and reshape the fire wall under the wiper cowl for clearance for the number 6 valve cover on the cummins.I have done this befor like tey told me and instructed, it sucked, I've done this befor and its eaiser and cheeper on the new way i'll guid you on...
FSG Transport LLC
post #8 of 29 (permalink) Old 12-03-2010, 11:14 AM Thread Starter
DIXIENORMOUS 4X4
Exclamation
almost done.
light is poor but i fabed my own mounts for the dodge intercooler and the the dodge radiator to fit in a Ford 7.3L diesel core support. i'll get pics and measurements.
fabed a new piolet bolt for the clutch fan pully, this should be 3 inch from radiator or 4 inch from radiator if you don't loose the originale bolt.
flipped exhaust manifold upside down to gain clearance between the A/C box.
low light sorry but, used a 7.3powerstroke turbo down tube to gain 2.5 inch extra clerance. Cut you flange off the cummins tube and the powerstroke tube then, weld your 5.9 flang in place on 7.3 down tube. Not recomended on a hx35.
Next pics, Twin elec. fans and thermostat relay, and radiator, intercooler mount specs.
FSG Transport LLC
post #9 of 29 (permalink) Old 12-03-2010, 12:53 PM
hayjayhorses's Avatar
those trans mounted parking brake assembly are very poor, I blew a few on an OBS F450, Is this 1992 truck a F450? if not dump the trans mounted break and replace (The cummins will kill it if my 460 did) it with a transfer case.
If it is a F450 I would just put a Dana 80 in it and go with the tallest gears I can find.
Is it a gas or a diesel 5 speed ? big difference in gear ratios between the two.
ZF 5-SPEED MANUAL (Diesel & Gas Ratios)
Diesel Gas
1st 4.14 5.72
2nd 2.37 2.94
3rd 1.42 1.61
4th 1.00 1.00
5th 0.76 0.76
I copied this from the gear vendor web site, I think the gasser 5th gear ratio is 0.72 like the ZF 6.
The gasser ratios with a US Gear overdrive would be sweet.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
The Following User Says Thank You to hayjayhorses For this addition to TDG:
Rebel Cummins (12-15-2010)
post #10 of 29 (permalink) Old 12-15-2010, 10:00 PM Thread Starter
DIXIENORMOUS 4X4
Exclamation
Diesel Gas
1st 4.14 5.72
2nd 2.37 2.94
3rd 1.42 1.61
4th 1.00 1.00
5th 0.76 0.76
Rebuilt 7.3 powerstroke zf 5 speed w/ new parking break assy.
The truck is a 1989 F-550 superduty 2X4 5-speed (460 EFI out)
Cummins Turbo. This truck also has an 18,000 lbs GVWR.
I do want to thank you on your gear ratio post that is helpfull for the next project.
FSG Transport LLC
1989 12 valve Cummins diesel motor forsale robs11260 Whats Been Sold 2 02-02-2008 12:31 AM
1989 5.9l standard cummins brad_26 5.9L Cummins (Pre 1994) 6 09-07-2007 06:32 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 05:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 05:29 AM
1989 Cummins 5.9 almost complete engine SPLnut Whats Been Sold 3 12-16-2006 03:42 PM
