Weight difference and distributions difference between a 7.3 and a 5.9 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lonesome7.3, this thread has received 10 replies and been viewed 1841 times.
post #1 of 11 (permalink) Old 11-30-2010, 09:21 PM Thread Starter
I am wondering what kind of weight differences there are in an early model 7.3 Powerstroke and a 5.9 12V. Also, do the V8 and I6 configurations play any kind of role as far as weight distribution? We are thinking about dropping a 12V I have into a 96 F350 crew cab chassis I just happen to have laying around and I am wonder how the suspension will be effected. I have a semi custom suspension idea in mind that includes using new stock coil springs from a two wheel drive F350. My way of thinking tells me if they support a 7.3 just fine a 12V should be a non issue. But I am also wondering about other quirks that might be weight related as well.
post #2 of 11 (permalink) Old 11-30-2010, 11:58 PM
gone fishin!
i beleve the 12valve is a little lighter....... think its around 900 Lbs dry with no flywheel/trans adapter. i think the stroke is around 950-980 dry.
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 11 (permalink) Old 12-01-2010, 12:09 AM Thread Starter
That is not as much of a difference that I thought there would be.
post #4 of 11 (permalink) Old 12-01-2010, 03:55 PM
Pardue the Traveler
New 0mega's Avatar
I thought the 12V was 1100lbs.
Singles Club member #250
New 0mega is offline
post #5 of 11 (permalink) Old 12-01-2010, 04:42 PM Thread Starter
Does it just have massive internals?
post #6 of 11 (permalink) Old 12-01-2010, 08:33 PM
gone fishin!
12 valve with p-pump is 905 LBs.... thats out of the cummins b series service manual
post #7 of 11 (permalink) Old 12-01-2010, 09:02 PM Thread Starter
Is that the dressed out weight?
post #8 of 11 (permalink) Old 12-01-2010, 10:22 PM
gone fishin!
everything but flywheel and adapter plate and tranny oil cooler. also is dry.
post #9 of 11 (permalink) Old 12-02-2010, 02:51 AM Thread Starter
That is not all that bad then.
post #10 of 11 (permalink) Old 12-03-2010, 09:08 AM
strawboss's Avatar
The 6.0 is A-Lot heavier than the 5.9. after I installed the 6bt in my 05 250 I noticed it sits up in the front now, So, i'm sure the 7.3 is heavier than the 6.0 so go ahead and do the swap You will NOT be disappointed!
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
What's the difference? Spindrift General Parts and Accessories 2 01-29-2010 04:12 AM
difference in 03 and 05 michael8840 2003-2007 6.0L Power Stroke 7 01-17-2010 01:43 AM
Any difference? dangerous196 5.9L Cummins (2003-2007.5) 0 03-23-2008 05:58 PM
What's the difference? dangerous196 5.9L Cummins (2003-2007.5) 8 02-21-2008 03:26 AM
Weight Difference? SuperManF250 2003-2007 6.0L Power Stroke 2 10-21-2005 04:33 AM
