Swap Questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6.0turbodiesel03, this thread has received 9 replies and been viewed 1521 times.
post #1 of 10 (permalink) Old 12-04-2010, 02:27 PM Thread Starter
You can call me French
6.0turbodiesel03's Avatar
Swap Questions
I'm starting the planning stages to swap a '97 12V into a superduty, but I have a few questions.
1. My donor truck is a '97 with a NV4500 that I just recently went through and rebuilt. I looked through the other threads, but noticed that a lot of people were not using dodge transmissions in their swaps. Is there a reason?
2. If I used the dodge transmission and transfercase, how would I get the driveshafts to mate up? Fords use flanges at the transfercase.
3. What would be the best truck to start with. Ive found a couple of older superdutys, '99 and '01 to be exact for about the same price with no drivetrains. One was a diesel and the other was a gasser.
I know these questions are beginer questions, but this is where I need to start the planning stages. Please give me your input!
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
6.0turbodiesel03 is offline
post #2 of 10 (permalink) Old 12-04-2010, 07:17 PM
Udderly Delicious
It's much easier to use the better ZF6(my opinion) in the swap because of driveshaft mating and mounting, but if you're wanting to save some money on adaptors just spend some time fabbing up tranny mounts and driveshafts. Then, there's always the problems that come with trying to line up floor hump tranny hole and transfer case shifter hole. Much easier to use adaptors to mate the 12V to Ford tranny and TC.
"To hell with a 6.0, make mine 6 in a row"
'03 "TNT Ranch Edition" F350 CrewCab Lariat 4x4 DRW 12V Cummins, P&P head with 60# valvesprings & O-Ringed, ARP 625 studs, Colt cam, 4K GSK, HX40S/HT3b Twins, ZF6spd. with Valair Ceramic/Kevlar, manual hubs, 3.73's, 5.5" lift/w 285 Dayton Timberlines and 2" Wheel Spacers.
Bullrack is offline
post #3 of 10 (permalink) Old 12-04-2010, 10:15 PM Thread Starter
Thanks for the reply, that is the kind of information that I am looking for. I could probably sell the NV4500 and find a ZF6, but then again, I'd almost rather fab it all up seeing that the adapter alone is $1,000 and that doesn't include the clutch or anything. Idk exactly what I'm going to do, I'm still planning.
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #4 of 10 (permalink) Old 12-06-2010, 04:09 PM Thread Starter
Anybody else have any input for me? I've done some searching online and found a couple of older trucks running the NV4500, but I haven't found any of the '99+ trucks running the NV4500. I guess I'm going to be looking for a ZF6 now:
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #5 of 10 (permalink) Old 12-06-2010, 08:55 PM
I only know a small amount compared to most guys but ill throw mine out there. The ZF6 is an excellent transmission and is much easier to do because its the one that comes stock in the trucks, therefore it fits perfectly. And as far as the truck to start with you definately want a diesel because there are a few subtle different between the two trucks like a lower rpm tach and a few others. Good luck with the build.
Diezeljunkie is offline
post #6 of 10 (permalink) Old 01-09-2011, 04:04 AM Thread Starter
Well guys, I thought I'd update everybody on the project. I still haven't bought the truck, but I'm piecing everything together so I'm ready when I do get the truck.
I've got the motor and trans out, and have started disassembly. I'm ditching the idea of putting the NV4500 in and going with a BTS built 4r100. I had a built auto in the 6.0 and loved it, plus I just got a job transfer where I have to drive further into the city, so a manual trans isn't as fun in traffic.
So far, the plans for the motor are as follows:
S200 over HT3B
5x.016 injectors
Tuned AFC
Benched pump with 4K springs
60lb. valve springs
Studded and O-ringed head
Slight port job on the head
Ported stock exhaust manifold (until I can afford a 3 piece)
Tunnel ram intake plate
There's probably some more odds and ends I'm forgetting, but that's the list as of now. Hopefully I can get started mocking the turbos up in the next week or two.
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #7 of 10 (permalink) Old 01-09-2011, 03:02 PM
Newbie
That looks like a fun project! Good luck and keep us updated.
You'll be happy with the BTS 4R100, thats what I have. Be sure to let Brian know it will be behind a 12V. He likes to lower the converter stall speed a bit.
I hope to have mine running in a few weeks
2002 Ford F350 Crewcab 4x4 7.3 PSD, powered by a 2004 5.9L Cummins
820 HP on 05/19/12
Deputydog is offline
post #8 of 10 (permalink) Old 01-10-2011, 05:09 AM
SSpeeDEMONSS's Avatar
S200 over 3B? 200 frame is awfully small. 5x.016? those are oversized for a 3B twin set as well. 5x.014 would be better.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #9 of 10 (permalink) Old 01-10-2011, 02:59 PM Thread Starter
When I talked with Lee from Contagious diesel, he said a set of 5x.016 VCO injectors would make a good set up. As far as the S200, I know it's a small frame, but it is 60mm with T4 housing and I got a good deal on it. These are the turbos we run on our farm equipment and we have never had a single problem with them.
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #10 of 10 (permalink) Old 01-10-2011, 09:23 PM
Send a message via AIM to slow00si
i know your scraping the manual trans idea but im going nv4500 in my 02 because its already a auto truck and has to be cut either way so why not stay with what i have and save all the money and hassle of the adapter plate, starter etc.
02 f250 ccsb lariat 12v and nv4500 swap in the works
slow00si is offline
Rear end swap questions SmokinCAT Medium and Heavy Duty 8 03-09-2010 02:40 PM
A Few D60 swap questions. KWT800 General Ford Truck and Excursion 5 12-26-2009 07:11 PM
96 OBS Dana60 swap questions yep 1994-2003 7.3L Power Stroke 3 04-05-2008 03:45 AM
SWAP questions? SPRGRUNTWV Diesel Conversion 1 03-29-2008 02:38 AM
ECM swap questions??? 99fordtruckguy 1994-2003 7.3L Power Stroke 1 01-19-2008 01:32 AM
