Fummins or newer 6.0l? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 24 replies and been viewed 5613 times.
post #1 of 25 (permalink) Old 12-14-2010, 06:53 PM Thread Starter
04lariatfx4crewcab's Avatar
I am in need of replacing my 6.0. I have found a 6.0l motor with 80,000 miles on it for $4250. but I still have to deal with the 6.0 problems.
I have also found a 1998 24v with a manual pump (comes with both pumps) for $1500. All the parts to do the conversion run at about $3500-$4000(is that about right?) so we are looking at around $5000-$5500 to do the fummins.
Which would be the better option?
My original thought would be to fix it and sell it then buy a gasser but if I replace it with the cummins I would just hang on to it. I just don't know if I can deal with $4000 repair bills again. I am missing my 2000 6.8 right now.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #2 of 25 (permalink) Old 12-14-2010, 10:14 PM
JPscustoms's Avatar
ummm fummins duh!
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #3 of 25 (permalink) Old 12-14-2010, 11:55 PM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
Fummins for sure! I know If mine takes a big dump on me thats whats going under the hood
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #4 of 25 (permalink) Old 12-15-2010, 05:10 PM
SSpeeDEMONSS's Avatar
fummins all the way!
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #5 of 25 (permalink) Old 12-15-2010, 07:05 PM
dzljon's Avatar
Fummins...
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #6 of 25 (permalink) Old 12-16-2010, 01:17 PM Thread Starter
Thanks for the replys guys.
But do my numbers look right about how much it will cost to do it myself. or is it still going to be closer to $10000. This is not a daily driver but I will be pulling a travel trailer 6-8 times a year.
Thanks.
Jakob
post #7 of 25 (permalink) Old 12-16-2010, 01:57 PM Thread Starter
Also I want to keep the 5r110 for now until it needs to be replaced it has 210000 miles on it too But still strong. I would like to keep it an Auto so the wife can drive it. Later put a built 4r100. I do not want to race the thing I just need it to move an 8000lb trailer around.
This thing has been sitting in the drive for over a month, I am getting tired of looking at it. That is one expensive boat anchor.
Jakob
post #8 of 25 (permalink) Old 12-16-2010, 04:32 PM
Newbie
If you get a 12V motor, you could save some money and I think you should be within your budget (depending on how much you spend on the motor of couse)
2002 Ford F350 Crewcab 4x4 7.3 PSD, powered by a 2004 5.9L Cummins
820 HP on 05/19/12
Deputydog is offline
The Following User Says Thank You to Deputydog For this addition to TDG:
04lariatfx4crewcab (12-22-2010)
post #9 of 25 (permalink) Old 12-18-2010, 07:31 PM
mine has been sitting for a year and a half!
post #10 of 25 (permalink) Old 12-19-2010, 07:16 PM
HRDROKN's Avatar
A 12 valve or 24 valve and keep the power reasonable until you get the trans you want. A $10K or less swap is very doable in this economy... motors can be found, but I would also keep an eye on a complete truck if that will work out for you as I've seen some dirt cheap runners!
HRDROKN is offline
The Following User Says Thank You to HRDROKN For this addition to TDG:
fummins gets a work out!!! JPscustoms Cummins in Fords 9 07-20-2010 02:52 PM
FUMMINS on facebook! JPscustoms The Parking Lot 8 04-06-2010 07:21 PM
here for the fummins... barrettgpeck Introductions 16 06-10-2009 07:17 PM
Fummins swap..? 6L strokin Diesel Conversion 5 05-10-2009 03:20 PM
700hp Fummins MrStroker Common Rail 38 04-22-2008 05:47 PM
