does it matter what 12v I use. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 8 replies and been viewed 1312 times.
post #1 of 9 (permalink) Old 01-06-2011, 03:11 PM Thread Starter
04lariatfx4crewcab's Avatar
I mean is there a difference as far as adaptor plates and such between using a 12v from a dodge truck or a 12v from a bus or larger truck that had an alison. Sorry I don't know enough about these motors and I want to find out all I can before I drop the hammer and pick up a cummins to drop into my truck. I would hate to buy a 12v or 24v that they don't make an adaptor plate for then have to spend more money to get one made.
Thanks
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #2 of 9 (permalink) Old 01-06-2011, 05:48 PM
TDG Mafia Goon
BombDocDiesel's Avatar
If you get a 12v that had an Allison behind it, most likely a 2000-series or older non-OD, you will need to find a cummins motor plate for the appropriate transmission. Those Allisons used an older SAE housing that will not fit a passenger vehicle transmission.
I have an extra Dodge motor plate I had left after I put the Allison in.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
The Following User Says Thank You to BombDocDiesel For this addition to TDG:
04lariatfx4crewcab (01-06-2011)
post #3 of 9 (permalink) Old 01-06-2011, 05:58 PM Thread Starter
Thanks bombdoc that is what I needed to know.
What if I get a 12v or 24v with the allison attached it is an AT545 will that fit in an F250? It seems I can get a tranny for about the same price as the adaptor plate if it fits then all I have to do is some drive shaft mods. but how will I hook up the 4x4?
Sorry fo all the questions.
Jakob
post #4 of 9 (permalink) Old 01-06-2011, 08:25 PM
TDG Mafia Goon
No problem brother. I asked a ton of questions.
The AT545 does not have OD. It's also a real bear if you need to work on it. Performance-wise it's not ideal. It's an industrial beast.
You would have to divorce mount your t-case. That can be done, but why? Do you have ESOF?
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
04lariatfx4crewcab (01-07-2011)
post #5 of 9 (permalink) Old 01-07-2011, 02:20 AM Thread Starter
That is what I was thinking. Seems lots of 12v and 24v are/were attached to the AT454. So might be better off finding a dodge 12v instead of a ford 12v.
Yes this truck does have the ESOF I liked the manual shifter on my 2000 I actually ordered the truck with the ESOF but they put the manual one in instead, I was glad it did not have the other.
As it is right now I am not too concerned if the 4x4 even works I would really like it too but it is not a need right now. I am in the wants and needs phase right now and the only need is, to get this lawn art running again before spring.
Jakob
post #6 of 9 (permalink) Old 01-07-2011, 02:57 AM
TDG Mafia Goon
I hear you. If it's a 12v it should be an AT545. The ISBs in MD trucks usually have a 2000/2400 behind them. You could make one work you just have to make a bracket and a few odds and ends to have a parking brake.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #7 of 9 (permalink) Old 01-07-2011, 04:07 AM Thread Starter
Parking brake, I have wheel chocks.
Jakob
post #8 of 9 (permalink) Old 01-07-2011, 04:43 AM
TDG Mafia Goon
Doesn't Texas still do annual vehicle inspections?
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #9 of 9 (permalink) Old 01-07-2011, 06:29 PM Thread Starter
I know a place that if your horn works you get an inspection.
Jakob
Size does matter. Truckie The Parking Lot 6 10-03-2007 06:54 PM
exhaust , does size matter????? bechapman1979 5.9L Cummins (2003-2007.5) 8 07-26-2007 09:47 PM
does this matter? edgerat 1994-2003 7.3L Chips & Tuners Forum 5 06-04-2007 12:54 AM
Does size matter?? truckerstyle04 General Ford Truck and Excursion 4 01-17-2006 12:12 PM
Guys, i need some serious help!!! no laughing matter Deezle1 The Parking Lot 12 06-27-2005 04:00 PM
