99 f250 getting 97 12v - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by exoticsrnw, this thread has received 9 replies and been viewed 1642 times.
post #1 of 10 (permalink) Old 01-30-2011, 03:41 AM Thread Starter
hello i have done a few of these in the early 90's body styles but now i got a new 99 f250 4x4 and am dropping my 97 12v on but im wondering what exhuast manifold are you guys using as my hx35w aint fitting real well with my heater box with the stock manifold could you guys help me out here
thanks
trever
90 ford f350 on a f450 chassie with a 97 5.9 and a 5speed # 10 plate slitly forward 3k govs afc housing forward afc spring kit star wheel adjusted forward kdp 14cm banks quick spool turine housing stock hx35 with banks big head set to 36lb boost and 5inch turbo back no muffler cold air intake valair 12.25 clutch with center upgrade red oak 5 hole 50hp injector
exoticsrnw is offline
post #2 of 10 (permalink) Old 01-30-2011, 04:18 AM
04lariatfx4crewcab's Avatar
You can try turning the manifold upside down. I hear that works. If not you might get a manifold from an industrial or medium duty truck.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #3 of 10 (permalink) Old 01-30-2011, 04:40 AM Thread Starter
ya i tryed that but that wont work ether im also considering a manifold from a 03-07 common rail
post #4 of 10 (permalink) Old 01-30-2011, 02:18 PM
Newbie
You can use a 3rd gen manifold and there is plenty of room.
2002 Ford F350 Crewcab 4x4 7.3 PSD, powered by a 2004 5.9L Cummins
820 HP on 05/19/12
Deputydog is offline
post #5 of 10 (permalink) Old 01-30-2011, 04:11 PM Thread Starter
will the hx35w bolt to that 3rd gen manifold and will i still be able to use my waste gate
post #6 of 10 (permalink) Old 02-01-2011, 07:11 PM
Pappy
MOPSD250's Avatar
It will work if you flip it upside down! You need to make a half inch spacer to get the turbo from the head so you can clock your turbo housings and you will need to wire your wastegate shut
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #7 of 10 (permalink) Old 02-01-2011, 07:55 PM
SSpeeDEMONSS's Avatar
why would you want to wire the wastegate shut? if it doesnt fit, make a new bracket so it will still work.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #8 of 10 (permalink) Old 02-21-2011, 01:58 AM
Pappy
MOPSD250's Avatar
It works though! There are alot of guys on here that have done that with no problems.
MOPSD250 is offline
post #9 of 10 (permalink) Old 02-21-2011, 07:52 PM
drives the drive pressure up too.
post #10 of 10 (permalink) Old 02-22-2011, 02:02 AM
Pappy
MOPSD250's Avatar
Ya you are right I wont argue that with you. Its still doable with no problems
MOPSD250 is offline
1888 f250 w/c6 to 5sp out of 89 f250 country_boy93 7.3L and 6.9 IDI (Pre 1994) 2 07-18-2010 12:11 AM
F250 Oasis request please! F250 4x4freak Ford Oasis requests 1 02-12-2009 09:12 PM
Fs 02 F250 Sc Sb scheidt27 Whats Been Sold 0 04-07-2008 03:26 PM
ok will 20 in. 07 f250 rims fitt on my 03 f250 ? 03f250 General Ford Truck and Excursion 7 03-02-2007 02:23 PM
2005+ f250 factory wheels on a 2004 f250 4wd kline925 General Ford Truck and Excursion 2 10-16-2006 05:46 PM
