ooppppsss carnage!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JPscustoms, this thread has received 22 replies and been viewed 5693 times.
post #1 of 23 (permalink) Old 02-17-2011, 12:48 AM Thread Starter
JPscustoms's Avatar
The cause!!
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #2 of 23 (permalink) Old 02-17-2011, 12:50 AM Thread Starter
JPscustoms's Avatar
Total damage- 6 pistons, 2 cyl walls scored, bent push rods, 1 broken lifter, turbo turbine wheel trashed, junked head, 2 valves, and the injector!
post #3 of 23 (permalink) Old 02-17-2011, 12:52 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
ouch!!!!!!!!!!
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #4 of 23 (permalink) Old 02-17-2011, 01:14 AM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
not good
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #5 of 23 (permalink) Old 02-17-2011, 01:54 AM
Dang!
I logged on tonight to check out your original build thread. My 7.3 threw a rod or two through the block last night and I'm contemplating a cummins swap. Apparently no engine is bullet proof no matter the make.
Weren't you contemplating a CR swap?
2001 F-250 7.3L Ext. Cab, SB 4X4, MBRP 4in, DIY intake, autometer pillar gauges, DP F5 tuner (40,80 and 120), ride-rite air springs, 08 Diff. cover.
1977 F-250 5.9L Cummins Nv4500 Dana 80
4wydnr is offline
post #6 of 23 (permalink) Old 02-17-2011, 02:24 PM Thread Starter
JPscustoms's Avatar
Yess i was! But i will be rebuilding the ole 12v and putting it back in. Everything breaks at some point!
post #7 of 23 (permalink) Old 02-18-2011, 01:33 AM
Pardue the Traveler
New 0mega's Avatar
That's ugly, looks like you were trying see if your valve would reach the oil pan
Singles Club member #250
New 0mega is offline
post #8 of 23 (permalink) Old 02-18-2011, 01:49 AM
SSpeeDEMONSS's Avatar
whose injectors?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #9 of 23 (permalink) Old 02-18-2011, 11:07 AM
UpstateDieselGuy's Avatar
Damn, that sucks! Good Luck with the rebuild. Chris
SOLD
UpstateDieselGuy is offline
post #10 of 23 (permalink) Old 02-18-2011, 01:49 PM
04lariatfx4crewcab's Avatar
Dang, Sorry to hear about that.
That is the nicest 12v I have seen love the paint job. I am planning to do something similar with mine. (The paint not the carnage)
How did it happen?
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
Some carnage pics.. Bcarriveau The Parking Lot 24 02-20-2011 02:40 AM
Carnage!! Flopster843 2003-2007 6.0L Power Stroke 18 01-18-2009 03:04 PM
Carnage spooled05 5.9L Cummins (2003-2007.5) 4 02-10-2008 07:28 PM
Dyno Day CARNAGE!!! Nasty Girl Events and Gatherings 26 12-06-2007 02:01 AM
carnage DT466man22 7.3L and 6.9 IDI (Pre 1994) 2 09-30-2007 09:28 PM
