Tranny to T-case adapter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 16 replies and been viewed 2152 times.
post #1 of 17 (permalink) Old 02-28-2011, 03:11 PM Thread Starter
04lariatfx4crewcab's Avatar
Is there an adapter to mate the Factory Ford T-case to a 47/re transmission? Or will I have to divorce them? I do have ESOF.
Thanks.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #2 of 17 (permalink) Old 02-28-2011, 10:40 PM
Old Fart
dbennett48's Avatar
Try; http://www.advanceadapters.com/ if they don't have it, it is not made.
Dave
Dave
Completely Stock.
KK6TNI - HAM Radio
dbennett48 is offline
The Following User Says Thank You to dbennett48 For this addition to TDG:
04lariatfx4crewcab (03-01-2011)
post #3 of 17 (permalink) Old 03-01-2011, 02:03 AM Thread Starter
cool I will check it out.
Thanks
Jakob
post #4 of 17 (permalink) Old 03-01-2011, 02:08 AM
I'm not sure but don't the late model Fords and Dodges use the same transfer case. Usually the problem is the imput spline count. I guess they couldn't agree on that.
char1355 is offline
The Following User Says Thank You to char1355 For this addition to TDG:
post #5 of 17 (permalink) Old 03-01-2011, 02:13 AM Thread Starter
man that would be nice I think I could gut the ford tcase and put the dodge stuff in it.
Jakob
post #6 of 17 (permalink) Old 03-01-2011, 02:31 AM
Send a message via AIM to slow00si
im currently putting my ford 273 behind a nv4500 by swapping input shafts but come to find out there is no bearing in existence to fit the input and be a big enough OD to fit the ford case from what im doing and cant find, so i have one last place to call that supposedly can make custom bearings if that doesnt work im going to machine a bushing and run the dodge bearing, and i was able to mic everything and find a seal just not the bearing, so good luck even though everybody else says the input swaps directly in i have no clue how they did it or where they found the bearing because ive spent days with no luck
02 f250 ccsb lariat 12v and nv4500 swap in the works
slow00si is offline
The Following User Says Thank You to slow00si For this addition to TDG:
post #7 of 17 (permalink) Old 03-02-2011, 12:07 AM
SSpeeDEMONSS's Avatar
its been done. i know someone on compD put a ford t-case behind a dodge tranny. dont remember where exactly it is but i know Roachie did it.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #8 of 17 (permalink) Old 03-02-2011, 12:09 AM
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
04lariatfx4crewcab (03-02-2011)
post #9 of 17 (permalink) Old 03-02-2011, 01:19 PM Thread Starter
Thanks Garrett,
I will look that up.
Jakob
post #10 of 17 (permalink) Old 03-02-2011, 01:55 PM
dzljon's Avatar
i am pretty sure you can swap the input shaft from the dodge case into a ford case if you are using the 271
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
The Following User Says Thank You to dzljon For this addition to TDG:
NP 518 tranny and NP 205 t-case BigHarvey56 Whats Been Sold 1 07-07-2010 10:46 PM
tranny adapter plate gon2sea 5.9L Cummins 12 Valve (1994-1998.5) 0 03-21-2010 10:53 PM
What type of tranny and T-case chevyforlife502 7.3L and 6.9 IDI (Pre 1994) 2 01-30-2009 08:14 PM
92 tranny and transfer case. 2blue11 Whats Been Sold 2 04-07-2008 11:27 PM
