FORD A/C on 5.9 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordtrucknut, this thread has received 30 replies and been viewed 29893 times.
post #1 of 31 (permalink) Old 03-06-2011, 09:15 PM Thread Starter
NOOB
fordtrucknut's Avatar
FORD A/C on 5.9
Has anyone put a Ford Compressor on a 5.9 Cummins conversion and mounted it up high and on drivers side?? Would love some detailed pics and how it was done...unless someone out there has a Cummins 5.9 High Mount A/C bracket from a Ford F-800 (PN #3930888)..Any help is greatly appreciated!!
fordtrucknut is offline
post #2 of 31 (permalink) Old 03-07-2011, 04:26 PM
04lariatfx4crewcab's Avatar
What are you going to be putting this in? why do you want it mounted on top?
I have a highmounted A/C on mine that I am taking off but my 5.9 came out of a freightliner FL60, don't know if it is the same.
The compressor is run off a seperate v belt
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #3 of 31 (permalink) Old 03-08-2011, 01:07 AM Thread Starter
NOOB
Is it the high mount that moves it up above the water inlet...but still over on the passengers side?? If so i'm interested...how much do you want for it?? I'm putting the 5.9 in a 78 Ford Crew Cab 4x4. Check and see if it has this number on it. PN #3930888
post #4 of 31 (permalink) Old 03-08-2011, 02:38 AM
nope the one I have puts the ac on top right smack dab in the center of the motor right above and in front of the first valve cover.
Sorry wish I could have helped.
BTW a 78 crew cab with a cummins will be one nice ride. we need pics.
Jakob
post #5 of 31 (permalink) Old 03-08-2011, 05:29 AM Thread Starter
NOOB
You got any pics of the way it is setup? I still may be interested.
post #6 of 31 (permalink) Old 03-08-2011, 03:15 PM
This is the only picture I have of it right now. you can kinda see it. I just don't think there would be enough room under the hood for that beast sticking up like that.
Jakob
post #7 of 31 (permalink) Old 03-08-2011, 07:16 PM
Steel's Avatar
Both of you should be running a dodge truck AC compressor mounted down on the passenger side front of the motor.
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
post #8 of 31 (permalink) Old 03-09-2011, 02:25 AM
Steel,
I am planning to reuse the ford ac compressor but put it down low where the dodge one goes. I just need to figure out how to mount it. That ac is already off and so is a bunch of other stuff. getting ready to do the KDP and rear main and Valve cover gaskets.
Jakob
The Following User Says Thank You to 04lariatfx4crewcab For this addition to TDG:
Steel (03-15-2011)
post #9 of 31 (permalink) Old 03-09-2011, 04:52 AM Thread Starter
NOOB
The problem with the Dodge bracket is it mounts the compressor too low and it interferes with the frame...I either need the Cummins high mount bracket that mounts the compressor above the water neck...or i need something to mount the compressor up high...don't care what compressor...and i am still interested in the bracketry that you have for that big old ginormous compressor....even if i don't use it..or a big compressor like that...lol
post #10 of 31 (permalink) Old 03-09-2011, 10:58 AM
strawboss's Avatar
I mounted the ford compressor on the lower pass side. Had a fella down the road make a one off. I'll try to get some pictures... gonna be hard. He might can make another one if you are interested.
Is there any diff in the 04 compressor, mine is an 05. I'll be glad to help you if I can..
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
ford 10.25 and 10.5 the same? brad's-powerstroked General Ford Truck and Excursion 6 07-16-2010 04:04 PM
Ford on Ford crime ToddPSD Road Kill, Bench Racing 19 07-25-2007 10:36 PM
NEED HELP! 91 ford dsl to 94 ford dsl motor tireguy Diesel Conversion 4 01-30-2007 12:10 AM
Bill Ford out as CEO of FORD fordt The Parking Lot 6 09-06-2006 02:08 AM
Screaming Ford Becomes Ford Double Dually King of Obsolete Medium and Heavy Duty 22 08-24-2006 01:48 AM
