coolant sensor adapter for 02 f250 with 12v - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by slow00si, this thread has received 9 replies and been viewed 5070 times.
post #1 of 10 (permalink) Old 03-13-2011, 05:42 PM Thread Starter
Send a message via AIM to slow00si
i know where to put the oil pressure sensor but where do i put the coolant temp sensor?
02 f250 ccsb lariat 12v and nv4500 swap in the works
slow00si is offline
post #2 of 10 (permalink) Old 03-13-2011, 05:58 PM
Newbie
Just remove one of the plugs on the passenger side top of head.
2002 Ford F350 Crewcab 4x4 7.3 PSD, powered by a 2004 5.9L Cummins
820 HP on 05/19/12
Deputydog is offline
post #3 of 10 (permalink) Old 03-13-2011, 09:51 PM
I would add close to the front.
Johnp3 is offline
post #4 of 10 (permalink) Old 03-14-2011, 09:11 AM Thread Starter
are they the same thread deputydog or do i need to buy an adapter?
slow00si is offline
post #5 of 10 (permalink) Old 03-14-2011, 11:43 AM
dzljon's Avatar
you will need an adapter, they are pretty easy to make but you can buy them for about $30 from fordcummins, GOS does not stock them but will give guidence to make them(preferred by me) as wells as autoworld.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #6 of 10 (permalink) Old 03-15-2011, 03:38 PM
i mounted mine at the back of the head where the factory one went. I bought a adapter at lowes and then tapped it to fit my sensor. I have a 6.0 though. It shouldnt be that different.
04 f-350 4x4 CC SB ZF6 12v. BDS Leveling kit 35x12.5x17 Nitto Trail Grappler, Glowshift 3n1, SBC 32506, HE351 37 psi, 4 GSK, AFC tunned, 17* timming
04_6.0 is offline
post #7 of 10 (permalink) Old 03-15-2011, 06:41 PM Thread Starter
do you remember the thread size on the 12v head?
slow00si is offline
post #8 of 10 (permalink) Old 03-15-2011, 10:22 PM
i believe it was 3/4" or 1" npt.
04_6.0 is offline
post #9 of 10 (permalink) Old 03-16-2011, 02:06 AM
3/8 and 1/2 NPT
Johnp3 is offline
post #10 of 10 (permalink) Old 03-18-2011, 02:44 AM Thread Starter
ok thanks everybody i ended up removing the dodge coolant sensor and broke both ends of the sensor off so all i had was the threaded body, then I drilled it out and tapped it for the ford sensor and it looks like it will work just fine for anybody else needing to do this its an option as i couldn't find an adapter locally.
slow00si is offline
FORD Powerstroke 6.4L Pressure Sensor Nipple Adapter dfuser Supporting Vendors Forum 2 09-17-2010 01:23 AM
Wanted: 2001 Cummins MAP Sensor Adapter BombDocDiesel Dodge parts wanted 2 11-05-2009 12:42 AM
Where is the coolant temp sensor? TLadd 5.9L Cummins 12 Valve (1994-1998.5) 2 10-21-2009 04:01 AM
3126 coolant temp sensor vcassens Medium and Heavy Duty 4 03-06-2009 12:09 AM
Thread size in block for coolant temp sensor? centennial60 2003-2007 6.0L Power Stroke 2 06-21-2006 02:09 AM
