last few questions and i should be good to go - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by slow00si, this thread has received 7 replies and been viewed 1731 times.
post #1 of 8 (permalink) Old 03-22-2011, 06:40 PM Thread Starter
Send a message via AIM to slow00si
i posted up on compd last night and have got 0 answers so seeing if you all can help me, the truck is a 02 f250 original auto truck converted to manual with a nv4500 but still running the esof ford transfercase with a 12v, thanks for any help and hopefully i can get all this done soon and then wrap up my downpipe and intercooler pipe fabrication and get my driveshafts done and enjoy my hard work because i miss driving my truck
1. the hydroboost line coming from the brake master back to the steering box do i T that into the line that goes from the p/s pump to the steering box?
2. for wiring up the grid heater can i use the stock ford glow plug relay or do i have to use the dodge relays?
3. to start do i jump the park and neutral wires together to bypass the safety switch? thats how all the import conversion's I've done work but not sure on these since the transfercase needs neutral to go into 4low from what ive read
4. reverse light wiring?
5. for the clutch hydraulics i used a ford master with dodge slave and dodge line ive got it to build pressure but the next day it takes about 10 pumps to get pressure again is it just not bleeding completely? any easier way than just pumping till my shoulder and arm is killing me?
02 f250 ccsb lariat 12v and nv4500 swap in the works
slow00si is offline
post #2 of 8 (permalink) Old 03-23-2011, 01:54 PM
Correct on the steering lines.
I ran a push button for my grid heaters with two ford relays controlling them. Works great and they are manual control.
Idk on this one my truck was already a stick when i started
same answer
Is there any leakage? if not maybe the slave is losing pressure after it sits for awhile. Did the slave have that pressure lock fitting on it?
04 f-350 4x4 CC SB ZF6 12v. BDS Leveling kit 35x12.5x17 Nitto Trail Grappler, Glowshift 3n1, SBC 32506, HE351 37 psi, 4 GSK, AFC tunned, 17* timming
04_6.0 is offline
post #3 of 8 (permalink) Old 03-23-2011, 04:24 PM
Newbie
I just grounded my Park/Neutral/Safety wire, and deleted my grid heater
2002 Ford F350 Crewcab 4x4 7.3 PSD, powered by a 2004 5.9L Cummins
820 HP on 05/19/12
Deputydog is offline
The Following User Says Thank You to Deputydog For this addition to TDG:
slow00si (03-23-2011)
post #4 of 8 (permalink) Old 03-23-2011, 07:32 PM Thread Starter
same answer
ok thanks and a few people responded on compd about the hydraulic issue sounds like i need to make a 24v dodge master cylinder work as the ford one doesnt move as much fluid to the dodge slave which sucks because i just bought a new ford master
slow00si is offline
post #5 of 8 (permalink) Old 03-24-2011, 03:21 AM
Newbie
I used a Ford 6.0 liter PS pump. It worked out perfect and lets you keep your master cylinder and everything else
820 HP on 05/19/12
post #6 of 8 (permalink) Old 03-24-2011, 07:16 PM Thread Starter
im talking about the clutch master not the brake master
slow00si is offline
post #7 of 8 (permalink) Old 03-24-2011, 10:18 PM
dzljon's Avatar
i am curious why you grounded your neutral safety wire?
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #8 of 8 (permalink) Old 03-25-2011, 01:01 PM
Newbie
Just the engine Park/Nuetral/Safety is grounded, I have the PCS P/N/S wired up correctly. Of course the purpose of the wire is to prevent the truck from starting in gear and the PCS does that for me.
820 HP on 05/19/12
Any good SCT Street tunes good for towing bigbore 2003-2007 6.0 Tuner Forum 1 03-02-2011 03:03 PM
F700 with 12V 5.9L - is this a good truck & a good deal? Michael Medium and Heavy Duty 11 03-06-2008 01:12 AM
Is 9.4 good in the 1/8th? superf350 Drag Racing 6 03-17-2007 11:36 PM
How good are ya? heinzboy The Parking Lot 9 02-03-2006 12:58 AM
First tow...tranny questions and chip questions 05TowBoss 2003-2007 6.0L Power Stroke 5 11-07-2005 11:17 PM
