It might be time! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TJJR, this thread has received 2 replies and been viewed 1095 times.
post #1 of 3 (permalink) Old 06-26-2011, 06:59 PM Thread Starter
It might be time!
I've been doing a lot of researching and thinking. And trying to convince the boss (WIFE) that i really need to do this. I'm not having any issues with my motor (probaly because all i have done to it) but i have come across a killer deal on a 2006 5.9 complete engine! All accessories and components down to the wire harness, ECU, and even the fan. I'm going to check it out this Friday and wanted to know if there is anything in particular that i should be looking for.I have been trying to research this year engine but haven't come up with to much. The only real thing I have heard is about a security key that the cr uses. The engine is still in the truck so i can hear it start up and run. Not to sure about the transmission yet. All i have to do is let the guy know i want it and he'll pull it out for me. Let me know whatcha think!
Tom
Early 2003 F350 6.0 4x4 crew cab
190cc, Innovative Tunes,Stage2 VGT-Hybrid from ID, Airdog 2, FULL egr delete, headstuds, and some other go fast stuff!
TJJR is offline
post #2 of 3 (permalink) Old 06-29-2011, 09:27 PM
04lariatfx4crewcab's Avatar
The next time something happens to that 6.0 you will be kicking yourself for not jumping on that good deal for a 5.9l. If you can get the tranny too the 5r110 is a PITA to tune and cannot hold up very long with a bad tune. Also it is easier to sell that 6.0l if it is running you can recover some expence that way. But it is easy for me to spend your money, so you will have to do what you feel is right.
Good luck
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #3 of 3 (permalink) Old 06-30-2011, 02:29 AM
Newbie
I agree about the tranny, if he's got the 48re grab it if you can.
Also, the security key (called a skimm file) isn't a big deal. Just get your ECM reflashed or get a recovery file from bob @ smarty
2002 Ford F350 Crewcab 4x4 7.3 PSD, powered by a 2004 5.9L Cummins
820 HP on 05/19/12
Deputydog is offline
12v time!!! JPscustoms Cummins in Fords 167 06-13-2009 05:15 AM
1'st time posting? 1'st time dodge diesel owner trikes 5.9L Cummins 12 Valve (1994-1998.5) 18 07-22-2007 01:24 PM
Long time Diesel driver, first time poster FireHunter Introductions 11 12-05-2006 07:00 PM
Hello, long time listener first time caller... Oliverpuller Introductions 14 11-16-2006 08:08 PM
