need help on 4bt cummins in a 1970 bronco - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kasprzak85, this thread has received 13 replies and been viewed 5676 times.
post #1 of 14 (permalink) Old 07-28-2011, 11:07 PM Thread Starter
gotta love black smoke!
I have a 1970 bronco that has a 302 in it and a 4 speed. It was my first ride and I bought it back from my brother. I am going to put some money into it and make it a daily driver but dont want to get killed on poor mpg. So the thought of a 4bt cummins looks like the best bet. I know that the nv4500 will bolt up to it. But I was thinking about a zf5/zf6 and a ford tcase would be a lil cheaper and easier to find. I want to stay with a standard tranny. Now on to my other question... I am going to be running 4.10 gears and 315/70/17 tires. What would be the best tranny/transfer case combo to get best mpg? I have heard the 4bt is most happy at 1900 rpm. I want to be able to cruise at 65 on highway. If anyone has any input thanks in advance.
Jon K
2003 F250 CC LB 4x4 PSD stock for now
1999 "Freight shaker" Century direct 10 Detroit 12.7
Pulling a 2001 Utility 53ft airride logistics Trailer LED all around.
sold 94 supercab LB 4x4 PSD ZF5 XLT , 357,000 miles(original motor) Bully Dog 4 pos chip, diy intake, 3in DP into 3in straight pipe, egt gauge, levelin kit and 265/75r16 on 16x8 rims
sold 2003 Mercedes SLK32 AMG Tax write off lol...
Kasprzak85 is offline
post #2 of 14 (permalink) Old 07-31-2011, 04:02 AM
04lariatfx4crewcab's Avatar
The ZF5/or 6 will work just fine but you will have to get an adapter plate those run about $750.00 but the availability of parts for the ZF's is much better than the nv4500's so it might be worth that extra cost. You can even go with an Eaton 6 or 10 speed if you have the room. Are you looking for a divorced or married transfer case? I think you might be ok with a late model NP271 but there may be others, lots of folks use NP205's There are a few older broncos with 4bt's in them so it can be done. There is a little more weight on the cummins than that 302 so you might want to check the suspension and axels.
good luck Keep us posted and we love pics.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #3 of 14 (permalink) Old 07-31-2011, 04:39 AM
hayjayhorses's Avatar
If you by a Destroked type trans adapter, Make sure you by the one for the Gasser ZF6. They are much easier to find and they are the same bolt pastern as the 6.0 trans.
My F250 with a ZF6 and 3.73 running 265/70/16 is turning 1800 rpms at 65mph. I think you may like 3.55 for your bronco 4bt.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #4 of 14 (permalink) Old 07-31-2011, 03:22 PM
strawboss's Avatar
So the eaton 10 spd will bolt up to the 4 and 6bt?
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
post #5 of 14 (permalink) Old 08-01-2011, 05:47 AM
yes all you need is to come up with a #2 flywheel housing for a Cummins B series.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
The Following User Says Thank You to hayjayhorses For this addition to TDG:
strawboss (08-01-2011)
post #6 of 14 (permalink) Old 08-01-2011, 01:14 PM Thread Starter
Why would I need an adapter plate? I can get a zf5 already bolted to it out of a bread truck...Axles and suspension are just fine I put 8 lug dana 44 up front and a 9in 8 lug in back.
Can so one do the math with 4.10s about how far about what will the 35in tires drop the gear ration to? 3.73? Lower?
Jon K
post #7 of 14 (permalink) Old 08-02-2011, 06:42 PM
I'm sorry you did not mention you have the ZF5 with the motor, and you were talking about putting an NV4500 on it, I assumed it was a Dodge NV4500 and you had the adaptor for that. If you want a ZF6 then you will have to make sure it is the same size bell housing, but I don't think you gain much with a ZF6 but a lower granny gear so it will not help with MPG's. I would just stick with the ZF5 if you have it/can get it.
Sounds like you are on the right track.
Jakob
post #8 of 14 (permalink) Old 08-02-2011, 10:31 PM
What it the final drive ratio for the transmission, .80 or .78 or .72 or maybe .64 from there it is no problem to figure the speed.
later is offline
post #9 of 14 (permalink) Old 08-03-2011, 01:09 AM Thread Starter
.76 if I read the specs right...
Jon K
post #10 of 14 (permalink) Old 08-03-2011, 01:49 PM
1900 RPM, .76 OD, 4.10 gears, 35 in. tires. you will be going 64MPH.
later is offline
My new toy, 1970 Blazer Bigking The Parking Lot 15 01-03-2011 03:21 AM
Cummins Bronco Diesel Duo Diesel Conversion 13 04-12-2010 01:07 AM
Cummins Bronco Diesel Duo Diesel Conversion 2 03-25-2008 06:25 AM
1970 Diamond Reo 1964reo Whats Been Sold 10 02-18-2008 02:47 AM
1970 Gmc with 6.2 diesel J.J. Melin 6.2L Diesel Engine 4 01-12-2008 01:06 AM
