6.0 degas bottle is in the way - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04lariatfx4crewcab, this thread has received 3 replies and been viewed 1882 times.
post #1 of 4 (permalink) Old 08-09-2011, 09:03 PM Thread Starter
04lariatfx4crewcab's Avatar
Now that the 12v is in the truck I was planning the plumbing for the intake, right at the air horn the degas bottle sticks out and down about 1" too far so I cannot get my CAC boot on. Has anyone had this problem? Is there another degas bottle that I could use like one for a V10, V8, 7.3l or even another car altogether? or is my motor sitting too far back or too high. there is about 3-4" between the oil pan and cross member and there is about 2" between the end of the block and the fire wall. I tried bending the bracket that holds the degas bottle but that only makes it worse.
Jakob
2004 5.9L/47rh Lariat FX4 Crew Cab Short bed. 213K miles 18" dbacks with nitto A/T grapplers, Zoodad mod, and 2000 turn signal mod. Limited Excursion bumpers front and back. Chrome grill, EGR delete, FICM delete, glow plug delete, HPOP delete, 2 cylinders delete, and 20 valves deleted
97 12v/47rh built by Garmon's
04lariatfx4crewcab is offline
post #2 of 4 (permalink) Old 08-09-2011, 09:59 PM
could you use the bottle from the cummins?
Richie
LI, NY
Rich
2003 f250 4wd 6.0 diesel crew cab long bed Lariat.
106k on the clock, stock
needs: tires, tuner, egr delete, coolant filter kit, blank check
silversuper is offline
The Following User Says Thank You to silversuper For this addition to TDG:
04lariatfx4crewcab (08-10-2011)
post #3 of 4 (permalink) Old 08-10-2011, 03:43 AM
ADMIN/MAFIA
neeltburn's Avatar
That wont work with the Ford Fan Shroud. Look at the 08 Swap and how Steel and Aden made the cold side IC pipe.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 4 (permalink) Old 08-10-2011, 02:34 PM Thread Starter
I talked with Steel yesterday. It looks like I can use an old catch can type resivoir I have floating around. If it doesn't work then I will just get the one GOS makes.
Does anyone have a diagram of how the coolant flows through a 12V? I have a hose comming off of the rear of the block at I think it is where most have the temp sensor. I would like to keep it because I heard there is a little bit of a problem with the #6 cyl heating up.
Jakob
degas bottle cap Overthetop05 2003-2007 6.0L Power Stroke 11 04-19-2010 05:43 AM
Gunk in degas bottle FFRyan 2003-2007 6.0L Power Stroke 7 11-10-2009 03:51 PM
Degas bottle question. StrokerDude 2003-2007 6.0L Power Stroke 23 12-31-2008 08:35 PM
Degas bottle whine killerford 2003-2007 6.0L Power Stroke 6 04-15-2008 08:50 AM
degas bottle nastys6.0 2003-2007 6.0L Power Stroke 5 02-24-2008 04:08 PM
