Early Bronco and 4bt..... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Big Stroker, this thread has received 20 replies and been viewed 25107 times.
post #1 of 21 (permalink) Old 06-10-2009, 07:44 PM Thread Starter
Yea its a long ways off but heres a start......:ford:
The idea at the moment(you know that always changes) is 4.5" Superlift with new springs all around and traction bars, an aluminum 2.5" body lift(to clear the cummins), disc brakes all around, custom bumpers and roll cage, course every other nick nack you can think of.
Axles New Yukon gears 4:10 for the Dana 44 and Ford 9". Going to disc brake both of them. I cut the shock mounts off the 9" for better angle later
New Gears
New Dana 44 carrier
I've also got my 4.5" Superlift in a week or so ago. New Springs, bushings, bulletproof brake lines, U-bolts, and traction bars.
Frame. I cut the motor mounts and shock towers off and then we sandblasted it clean. I don't have but one good pic of it in primer
Here is a pics of the two 4BT Cummins motors I have...Right now they are out getting machined and reworked
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #2 of 21 (permalink) Old 06-10-2009, 07:45 PM Thread Starter
This Bronco is what I'm starting with.....
Now for the best part!!!
Reciepts Lots and lots of them
Now the truck
Lots and Lots of extra parts
Complete rebuilt new bushings, sandblast, gears, brakes, hubs whole nine yards
Finally picked the colors out also. Hard to see but I think it will be SWEET
Ford Sonic Blue
Ford Medium Platinum Met
#27
post #3 of 21 (permalink) Old 06-10-2009, 07:47 PM Thread Starter
I didn't have my camera during progess so this is after math pics
Last week finally had some time to work on the Bronco...
Had a couple buddies come over to the shop and we all picked the body up and removed it from the frame. We swapped the old frame with one that we had ground down all the welds removed the shocks and motor mounts. I then had it sandblasted and we primed and painted the whole thing.
So basically we tore it completely apart. Swapped in the new frame, installed my 4.5" Superlift and my homeade body lift. Springs from a 70's F150 to hold the motor wieght
As for the body lift when I worked at the offroad shop Jeep kits came with these 4.5" solid aluminum blocks to use as bump stop spacers. We never did install them. Turns out if you cut them in 3rds they make perfect 1.5" body lift blocks. the great part is they already have holes the same exact size as the body bolts from a bronco.
So cut um down and bingo bango 1.5" body lift block for FREE!!!
Anyway here are the progress pics..
Block before:
Block after:
Block Installed:
Old Frame:
New Frame:
New Front springs:
All installed:
#27
post #4 of 21 (permalink) Old 06-10-2009, 08:05 PM
plainredtruck's Avatar
Images: 11
That looks like a really cool project and one I can't wait to see complete.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #5 of 21 (permalink) Old 06-10-2009, 09:01 PM Thread Starter
prt
Its been a long fight but...Engine shop called this week. Going to be able to finally take a look at the motor. So mebbe I will have that back in the next month
Got the tranny and tcase last night
So I'm getting further and further
#27
post #6 of 21 (permalink) Old 06-10-2009, 09:22 PM
********* and Mafia #90
Bcarriveau's Avatar
I will be watching
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #7 of 21 (permalink) Old 06-11-2009, 05:05 AM
I was planning the same project with my 72, but no time
I have a 4BTA-ZF-NP205 and a set of 3/4 ton (8 lug) axles from a 78 F250 for sale.
BONE STOCK
444turbodiesel is offline
post #8 of 21 (permalink) Old 06-11-2009, 05:12 AM
TDG Mafia Member #56
Dieselwrencher's Avatar
Very nice project! That bronco is way nicer than the turd 69 i have sitting in my yard.
Putco light bar
Dieselwrencher is offline
post #9 of 21 (permalink) Old 06-11-2009, 06:02 PM
EB.Bldr's Avatar
Looks like you've made some headway since the last time we talked. Looking good!!
EB.Bldr is offline
post #10 of 21 (permalink) Old 07-30-2009, 10:13 PM
Chirpin Tires...
OOWeaver68's Avatar
any updates Paul?????
2008 Ford F-250/4x4/Crew Cab/Short Bed/King Ranch/All Options/Viper 5901 Alarm-Remote Start
Spartan 275 Tuned/AFE Stage II CAI/Spearco Intercooler/RCD Intercooler Pipe/DieselSite Intercooler Boot Kit
Powerstroker67's Downpipe/Cat/DPF Delete/MBRP DPF-Back Exhaust
2.5" Ready Lift/Bilstein 5100 Off-Road Shocks/20x9 XD Ambush Black/35x12.50R20 Toyo M/T
Sto-Rage Underseat Box/Transfer Flow 40G Fuel Tank & Toolbox Combo
OOWeaver68 is offline
Cummins Bronco Diesel Duo Diesel Conversion 13 04-12-2010 01:07 AM
OBS Bronco Tank imported_Dieselfever Whats Been Sold 2 09-25-2007 02:42 AM
90 bronco sas 3/4 ton lockers etc. paranoidredneck Whats Been Sold 1 07-04-2007 01:48 AM
79 bronco IDI 7.3 scratchynum1 Diesel Conversion 25 03-18-2007 04:53 PM
Bronco with a 7.3 racehauler 1994-2003 7.3L Power Stroke 3 02-12-2007 07:06 PM
