03 CR oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 375.0ford, this thread has received 3 replies and been viewed 1009 times.
post #1 of 4 (permalink) Old 07-10-2009, 02:03 AM Thread Starter
03 CR oil leak
Looking for info, installed an 03 Cr in my 03 F250, engine had 130k very minor oil leaks at rocker cover I replaced rocker cover and valve cover gaskets before i installed the engine, I used 5w40 shell rotella synthetic, I drove it 300 miles, and oil is coming through the injector plug up front,it apears to be coming right through around the wires, any thought or direction on repairing this problem would be great, Thanks in advance for any help.
03 F250 CC FX4 5.4 Now a Cummins 5.9 CR
1937 Ford 2dr sedan slantback 5.0 HO
375.0ford is offline
post #2 of 4 (permalink) Old 07-11-2009, 10:01 AM
Did you install head studs? And did you clearance the aluminum cover for the back studs?
coope3 is offline
post #3 of 4 (permalink) Old 07-12-2009, 12:20 AM Thread Starter
No I did not put studs, just replaced the gasket, is the 5w40 to thin? just came back from a drive and theres more leaks, this engine was almost dry when I removed it. now its leaking alot.
post #4 of 4 (permalink) Old 07-22-2009, 01:40 AM Thread Starter
It was the vavle cover gasket don't know how or why but there was a divit in the gasket replaced it again yesterday, looks ok now, Thanks for the help.
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 04:17 AM
Oil Leak in X. cdiesel 1994-2003 7.3L Power Stroke 15 01-03-2007 10:03 PM
oil leak flycut 2003-2007 6.0L Power Stroke 1 12-28-2006 10:52 PM
Oil leak help again Josh F250 2003-2007 6.0L Power Stroke 4 12-14-2006 01:56 PM
ok, now i got a leak...HELP TXHNTR 2003-2007 6.0L Power Stroke 10 05-28-2006 07:53 AM
