PO882 Code I cant get rid of!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 03f3507.3, this thread has received 4 replies and been viewed 2411 times.
post #1 of 5 (permalink) Old 10-13-2009, 11:43 PM Thread Starter
Ok im running an 04.5 commonrail with a 48re in my 2003 F350 and I have tried to fix this code to no avail....I wired in the relay I was told to do running a 15amp fused wire from the battery to the 30 on the relay, a ground wire to 86 on the relay, the yellow/orange wire(T16 for the transmission control relay output that goes to the transmission) to 87 on the relay, and then the yellow/dark blue wire(t515 for the transmission control relay control that goes to the ecm) to 85 on the relay. To my knowledge this is the only wiring that would affect this so does this mean my TCM is bad? or am I wiring something wrong? I believe this is why my tranny is in limp mode and not locking the converter properly..
Red 2003 F-350 Crew Cab Longbed
Built 04.5 CTD, Billet Tranny, HUGE Twins, Lots of fuel Big thanks to Industrial Injection, Georend Brothers, Luke Hunely L&L Diesel, Farmers Machine, and Drivelines Plus!
Black 2008 F-350 Crew Cab Shortbed Tow-rig
03f3507.3 is offline
post #2 of 5 (permalink) Old 10-15-2009, 01:06 AM
EB.Bldr's Avatar
Not really familiar with that code. What is it?
What are your symptoms with the trans being in limp mode?
EB.Bldr is offline
post #3 of 5 (permalink) Old 10-15-2009, 01:37 AM Thread Starter
It's transmisson control reley voltage too low and if you take of in drive it takes off in 2nd and stays there only way to get it to shift is to manually do so...anyway you can found out what was done to ur wireing for ur 48re on ur conversion maybe I'm missing something...
post #4 of 5 (permalink) Old 10-15-2009, 06:02 PM
EB.Bldr's Avatar
I believe I have that code as well. My trans has never shifted like I would like but it does start in 1st. I'll find out what I can and get back with you. You dont also have a rather LARGE slam when it goes into OD by chance?
EB.Bldr is offline
post #5 of 5 (permalink) Old 10-15-2009, 10:46 PM Thread Starter
mine does not shift at all on its own but does slam due to tq management on 4 and my throttle cable zip tied back...but let me know what u find...
Can I Put J-Code Exhaust Manifolds On a C-Code Engine JLanzino 6.2L Diesel Engine 6 10-08-2009 02:29 AM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 02:36 PM
Code Help? allstarsixo Duramax 2006-2007(LBZ & LLY) 3 04-08-2008 03:23 PM
Code fuzzys69 2003-2007 6.0 Tuner Forum 2 02-10-2008 01:53 PM
DT With eng code axle Medium and Heavy Duty 5 07-07-2007 11:22 AM
