2004 f350 12v questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 04_6.0, this thread has received 34 replies and been viewed 3775 times.
post #1 of 35 (permalink) Old 05-03-2010, 11:55 PM Thread Starter
I have recently started putting a 98 12v into my f-350. My question are where did yall mount your factory 6.0l sensors to make your factory gauges work i put the coolant in the back of the head is that ok? Also did yall use the ford fuel pump and let the extra fuel retun to the tank. Thanks for any information or any help.
04 f-350 4x4 CC SB ZF6 12v. BDS Leveling kit 35x12.5x17 Nitto Trail Grappler, Glowshift 3n1, SBC 32506, HE351 37 psi, 4 GSK, AFC tunned, 17* timming
04_6.0 is offline
post #2 of 35 (permalink) Old 05-04-2010, 12:42 AM Thread Starter
I also have another question. What accelrator cable did yall use? Ive have read that some use the dodge and some use the ford one? Sorry for all the question im just trying to get parts ready while i wait for my destroked parts to come in.
04_6.0 is offline
post #3 of 35 (permalink) Old 05-04-2010, 11:55 AM
Born in the USA
patriot2500's Avatar
Send a message via AIM to patriot2500
Should PM or read the build by JPSCustoms on here as he swapped a 12v into his '04 or '05 F350. He will be able to help you out.
Tom
2004.5 Dodge 2500 QC/LB - Goerand 48RE, 4.10's, AFE Stage II, Magnaflow 5" TBE w/6" tip, Smarty TNT/REVO, PacBrake, ATS Manifold, ATS Triple Lok Commander, ISSPRO EGT, Trans, Boost on the pillar, FASS 150, 35X12.50 Toyo M/T's on '06 wheels, Mag/Hytec front/rear diff covers and trans pan, Full Recon Lighting, Prodigy Brake Controller, Silverstars, WeatherGuard Toolbox, BackRack, Kenwood Radio w/ 2 MTX Thunder 4500 subs, Sirius, CompuStar Alarm/Remote Start, Husky Floormats
Thanks to Kenny @ KTPerformance.net
2007 Honda Foreman 500 ES - Rack bag, gun racks, trailer hitch, Cycle Country plow, 27" ITP's on ITP Delta Steel Wheels
patriot2500 is offline
post #4 of 35 (permalink) Old 05-04-2010, 12:38 PM Thread Starter
I was hoping he would chime in. Ive read his build thread through a couple times just never found the anwser i was looking for. ill shoot him a pm. thanks for the help
04_6.0 is offline
post #5 of 35 (permalink) Old 05-04-2010, 12:51 PM
JPscustoms's Avatar
coolant sensor in back of the head, oil psi sensor goes just below the p-pump were the dodge psi sensor was. did you get a destroked tach kit??? and ya use the dodge cable, just have to drill a hole in firewall and square it out with a file so the dodge cable clips in. i used a fass fuel pump
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #6 of 35 (permalink) Old 05-05-2010, 12:24 AM
Pappy
MOPSD250's Avatar
EXACTLY .
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #7 of 35 (permalink) Old 05-05-2010, 12:40 AM Thread Starter
Did yall have to buy some kind of adapter for the oil pressure gauge to fit form the 6.0 to the cummins? Ive been to three parts stores and lets just say they arent much help. As far as a tach kit not yet trying to figure out my own setup but i cant really test it till the motor is in and im still waiting for destroked parts. Thanks for the information yall i really appericate it.
04_6.0 is offline
post #8 of 35 (permalink) Old 05-05-2010, 02:19 AM
JPscustoms's Avatar
i made my own adaptor for the oil psi
post #9 of 35 (permalink) Old 05-05-2010, 02:27 AM Thread Starter
you got some pics or can you explain how to do this. Is the 6.0 standard threads with a o-ring to seal? Also are you happy with your south bend setup?
04_6.0 is offline
post #10 of 35 (permalink) Old 05-06-2010, 01:54 AM Thread Starter
Also the tach kit from destroked what does it plug into on the 6.0l harness? Thanks again for the help guys.
04_6.0 is offline
2004 f350 cc/lb/drw/2wd/6.0l/at Strictly Diesel Vehicles For Sale 4 12-23-2009 09:36 PM
2004 f350 Bcarriveau 2003-2007 6.0L Power Stroke 8 11-01-2009 01:29 PM
2004 F350 DRW stuff boobin Whats Been Sold 3 04-28-2009 12:50 PM
2004 6.0 powerstroke into 92 F350 7.3 brewdog Diesel Conversion 3 08-21-2007 01:37 AM
2004 f350 6.0 rayb 2003-2007 6.0L Power Stroke 13 10-30-2005 06:57 PM
