emissions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by AmarilloSD, this thread has received 9 replies and been viewed 1846 times.
post #1 of 10 (permalink) Old 05-13-2010, 04:42 PM Thread Starter
AmarilloSD's Avatar
emissions
Ive been steadily researching common rail swapping my 06 6.0 Hard... ive pretty well got all the info i need its just a matter of time and money now, however something else has got me a little feared.. this june emissions laws will be changing here in utah, the previous laws were just sniffer testing on the dyno, my trucks have all passed tunes no tunes no cats no egr with flying colors, however the last update they are now scanning the trucks like an obd2 test, however we have seen to get by that with just clearing all the codes before scanning it as they arent as strict as the obd2 test with all the readiness bs, my concern is if this update in june gets a little stricter how will a CR swap affect this? will it still pass? im going to be doing an 05 or 06 CR which will be the same emissions year as what came out of my truck however my truck does have the cali emissions on it?
who knows what?
2006 f350 C.C.SB Amarillo Edition- Afe Stage 2 intake, SCT, mbrp 5" turbo back with 6" tip, 7" icon lift,325/50/22 dynapro atms on 22x11 black XD diesels, keystone heat extractor hood, 4.30 gears, 03 turbo DR/icon traction bars, Hd Heads, Painted front and rear bumpers, arp head studs, Welded EGR
wish list/coming soon-banks ic, regulated return fuel system, Tuned FICM, but not if i do a CR cummins first!
AmarilloSD is offline
post #2 of 10 (permalink) Old 05-14-2010, 02:31 PM
Steel's Avatar
With your truck having CA emissions on it, that throws a twist in it. However, as long as you have a same year or newer motor that you are putting in your truck, you should be good. We don't have emissions out in our neck of the woods, so I'm not all too familiar with the procedure on the OBDII scanning, but if they are looking for codes, you could have someone like Wagner write you a recovery file that shuts off all of the extra codes like transmission, ground shorts, A/C, and all of the other conversion associated codes that stick in the ECM. Other than that, an Amarillo edition truck with a CR would be Sweet! Good luck!
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
post #3 of 10 (permalink) Old 06-29-2010, 04:00 PM
Amarillo ford in so cal
I have an amarillo done here in Socal and am currently trying to figure out how to get it smogged . So far the ref has told me it has to have the dodge tranny to go with the motor since the ecm and the tranny were connected .
ID:	26435   Click image for larger version
2005 F250 AMARILLO .2006 CUMMINS CR. DESTROKED ADAPTERS .ALLISON TRANS AND CONVERTER BY DESTROKED . TURBONETICS STAGE 2 OVER SX475 . FIRE RINGS . HEADSTUDS . DYNOMITE INJECTORS . . SPEARCO INTERCOOLER . FLUID DAMPER . COOLINGMIST WATER INJECTION . FASS 150 . GLACIER INTAKE . BANKS EXHAUST . 4.30'S AND DETROIT LOCKERS . SMARTY .
BIGYELLOWF250 is offline
post #4 of 10 (permalink) Old 06-29-2010, 06:35 PM Thread Starter
AmarilloSD's Avatar
okay i just spoke to the local health department on this issue, he first said let me state its against federal and state law to do the swap as it was never certified for use in the ford chassis.. that being said however if it has been done already, he said you must bring it to us to have it certified. to pass the certification process it means you must have the same year or newer engine, and all emissions equipment of both vehicles, so it would need to retain egr and catalytic converter as the 6.0 has, does the 06 5.9 have this??
post #5 of 10 (permalink) Old 06-29-2010, 07:45 PM
EMISSIONS
I have already been throught the first steps here in Ca. The refferee station passed me on to the people that give eo #s to people that make aftermarket parts . I am working on making the cel function and removing all codes from cummins ecm and ford pcm . Then I have to go to their facility and have it all checked out . And here you have to have all the equipment of the newer engine not the equipment from the ford also , thankfully because the 06 cr didnot use egr .
post #6 of 10 (permalink) Old 06-30-2010, 06:09 PM Thread Starter
AmarilloSD's Avatar
how do you have yours wired in? are you using the painless harness?
post #7 of 10 (permalink) Old 07-01-2010, 12:41 PM
em
I am using the original dodge harness grafted to the ford harness . The wiring is not very dificult .
post #8 of 10 (permalink) Old 07-01-2010, 07:12 PM Thread Starter
AmarilloSD's Avatar
the setup im going to purchase has what you have a grafted harness, however from what i understand the painless harness has an obd connector on it, with this setup i think it may be possible to shut down any potential CEL and make it so that the ref/inspector can plug into both and see what they need to
post #9 of 10 (permalink) Old 07-02-2010, 03:23 PM
OBD
I have the obd connector , it is very easy 2 can wires a power and ground . Bob Wagner is working on shuting off the 4 codes I cant get rid of in the cummins ecm . And Tad at Elite diesel is working on the 38 codes that I have in the ford pcm . The ford one needs to be clear so that when the ref cycles the key , the check engine light will turn on then off again .
post #10 of 10 (permalink) Old 12-06-2010, 05:34 PM Thread Starter
AmarilloSD's Avatar
any update on the codes?
EGR and emissions Hotwheels34 2003-2007 6.0L Power Stroke 18 06-18-2009 05:56 AM
Emissions. Taco XL 1994-2003 7.3L Power Stroke 4 04-09-2009 01:46 PM
Emissions? EB.Bldr Diesel Conversion 6 01-21-2009 12:05 AM
Emissions? One Fast Harley 2003-2007 6.0L Power Stroke 5 07-19-2007 08:00 AM
With New Emissions BROKER Medium and Heavy Duty 8 08-11-2006 08:38 PM
