Leveling kit questions? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 3 replies and been viewed 2405 times.
post #1 of 4 (permalink) Old 10-18-2010, 04:21 AM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
I wanting a leveling kit on my 97' And i was just curious, if this a good buy?
http://cgi.ebay.com/ebaymotors/Dodge...Q5fAccessories
How hard is it to put in? and is it really worth it? Thanks
Bryan
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 4 (permalink) Old 11-16-2010, 05:19 PM
bmoeller's Avatar
Sure beats the expensive springs. Well in excess of $200 for the taller springs.
Don't forget longer springs.
"Obama = Hoax and Chains"
bmoeller is offline
97CumminsTurboDiesel (11-17-2010)
post #3 of 4 (permalink) Old 11-16-2010, 05:57 PM
BUCK2's Avatar
Those look just like mine except I did the 1.5 spacer. I did mine and it was fairly easy just drop the axel as far as you can. I unbolted the brake calipers and you will need a really good pry bar to compress the sping some to get them in there! Some say to also un bolt the track bar, but I did not.
A few hours and few drinks and with a friend it is pretty easy!
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
The Following User Says Thank You to BUCK2 For this addition to TDG:
post #4 of 4 (permalink) Old 11-17-2010, 01:06 AM
TDG Mafia
Jeffybuilt's Avatar
I have 2 sets just like that. One on my 97 1/2 ton and one on my Cummins. As stated above, they are pretty easy to install, especially if you have spring compressors, and enhance the stance of the truck. Good buy in my opinion.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
The Following User Says Thank You to Jeffybuilt For this addition to TDG:
leveling kit questions 4play General Dodge Discussion 9 07-21-2009 02:40 AM
leveling kit delps04 Supporting Vendors Forum 2 04-03-2008 12:17 AM
Questions about a Leveling kit on a 2008 SD Shawn General Ford Truck and Excursion 3 09-19-2007 11:22 AM
Leveling Kit Mlhaynes8302 General Ford Truck and Excursion 39 09-07-2007 11:48 AM
First tow...tranny questions and chip questions 05TowBoss 2003-2007 6.0L Power Stroke 5 11-07-2005 11:17 PM
