WILL THEY FIT - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fasttoys450, this thread has received 2 replies and been viewed 1485 times.
post #1 of 3 (permalink) Old 10-27-2010, 05:50 PM Thread Starter
fasttoys450's Avatar
WILL THEY FIT
I Have a 1998 1 ton doully i am wanting to know if 35 in tires will fit frt and rear without a leavling kit thanks
fasttoys450 is offline
post #2 of 3 (permalink) Old 10-29-2010, 01:50 AM
JDolezal's Avatar
The trucks in my sig have all run 35x12.5 tires with stock suspension. If they are on stock wheels they will rub the radious arms when turning all the way. If the wheels have an offset that makes them stick out kinda far they will rub the plastic inner wheel well when turned all the way.
91.5 Dodge 250, rclb, 4x4, Getrag, little extra fuel and timing, straight pipe
94 Dodge 2500, rclb, 4x4, NV4500, little extra fuel and timing, straight pipe
95 Dodge 2500, rclb, 4x4, auto, gasser.
02 Dodge 2500, rclb, 4x4, NV4500, Edge EZ, straight pipe
JDolezal is offline
post #3 of 3 (permalink) Old 11-16-2010, 05:09 PM
bmoeller's Avatar
Probably need the leveling kit and WILL need spacers between the rear tires. Side walls will touch otherwise.
The '98 should have 215/85/16 rubber stock. 235/85/16 will fit without needing spacers for the rear, but you need the to keep the tires inflated close to max cold so they don't touch. Maybe 1" gap between them.
The later 2nd gen duallys ('01 and '02 maybe?) have a deeper dish to them, and came with 235/85/16 rubber stock. My '99 has the deeper rims on it now, and hoping to get 255 rubber on it.
"Obama = Hoax and Chains"
bmoeller is offline
